banshdog
Everything posted by banshdog
  1. how was silver lake???, heard it was BUSY!!!! You should be pretty close, may need to adjust your needles a notch.....
  2. 1 vote for waste of time/money.
  3. With the lid on the airbox, probably gonna be around the 280 or 290 mark....
  4. Choke tube in place...
  5. Not sure on the exact number, you will have an increase with aftermarket pistons. BUT..... do not bore the cylinders to get more power. Boring the cylinders is a repair, not a mod. you will gain some displacement, but also know that your stock cylinders can only be bored so much, use them wisely.
  6. thats what its here for.
  7. The line where the cases come together is 0.
  8. make sure the choke tube is on (simple tube from carb to carb), clean the carbs???? jets, bowls, etc.... who did the rebuild? pistons in correctly? rings? reeds?
  9. Unplug that bitch........
  10. TORS...... does your bike have the parking brake? is it stuck on?
  11. uh.... no.
  12. Nerfs..... http://www.bansheehq.com/forums/index.php?showtopic=58361
  13. Nerfs..... http://www.bansheehq.com/forums/index.php?showtopic=58361
  14. Nerfs for sale here....... http://www.bansheehq.com/forums/index.php?showtopic=58361
  15. I would piece it back together and sell it. I would think that parting it out and trying to sell all the pieces would require more time and effort.
  16. maybe put this in the "for sale" section
  17. Where are you located? alititude? temperature? have you checked your compression? What is "acting up" ???? need more details.....
  18. MICHIGAN here..... waiting for warm weather.
  19. Clean the carbs
  20. Did you hold the throttle wide open when testing the compression?
  21. I would suggest you go up on your pilot jets.
  22. If you are going from a stock bike to the mods you just listed.... yes you will definately notice a difference.
  23. Trace that line back and see where it is coming from. Does your bike have the coolant overflow bottle removed? I recall someone on here with a problem where some coolant lines were crossed with the case breathers. Dont take it in, im sure that with HQ members help, the porblem will be traced.
  24. banshdog
    back tires
    like these....?
