banshdog
Everything posted by banshdog
  1. Posting this question for a friend... From what I know the only thing done on the rebuild was the top end. However, the guy said the top end went because of an air leak from the boost bottle, he removed it and capped the intakes. 00tbanshee - what do you mean by pickup gap? and what should the gap be? tommy346 - no, not smoking bad.
  2. Hey all, 1999 Banshee Ported cylinders 35 mm kehin carbs w/ 162 mains New Reeds Pro Circuit Pipes Cool Head Pro Design Intakes New Top End - 3 over. Bike is in Las Vegas ran good for 2 years, was just rebuilt. went through about a half tank of fuel for break in, but bike bogs and wont "clean out" and get the RPM's up. - New plugs - Tried rejetting (leaner) no change, so went back to the 162's Any ideas? Thanks in advance for any help.
  3. Posting this for a friend. See Pic. Email sirtekconstruction@yahoo.com, with questions or offers. Mike.
  4. Rims and tires for sale. See pic. Make offer. Also may consider trades.... looking for a set of sand tires.
  5. I have a 6" over swingarm and want to change it out for a 2" over. see pics, let me know what you have....
  6. Havent been on in a LONG time..... airbox still available MAKE AN OFFER.
  7. Carb Slides were in backwards..... all is well for now..... THANKS ALL FOR THE RESPONSES. MIKE
  8. Cylinders measured to 20 over and the rings were Weisco for the same size..... I have no idea what is going on, but the left side is not running. Right side seems fine. F F F Anyone else have any ideas?
  9. Cylinders were measured, pistons were not. Did not set ring end gap -- what is that? do i need to? is it too late now? Cylinders were not honed, and yes it ran prior to the re-ring. carbs appear to be sync'ed, as far as i can tell visually.
  10. Hey all, hope you have some insight for me..... 03 shee, mods listed in sig.... Had low compression the end of last year, so I pulled the top end apart.... cylinders looked great (no gouges) and still measured at 20 over. The pistons looked good too, nothing broken. So I went ahead and put new rings in it and put it back together. When i fired it up, it was running bad, sounded like the choke was on.... Tore back into it to make sure everything was right, took the bowls off the carbs, etc. put it back together and it ran a lil better. The right cylinder is firing normal, the left is not. at low rpm's its not firing, at higher rpms it starts firing. Tried new plugs..... same issue. checked spark, spark looked a little weaker on the left side. tried switching plug wires L to R, same issue..... I am stumped, ANY IDEAS?????
  11. For Sale..... I replaced stock covers with billet on my 03 shee. I have...... Water Pump cover Clutch cover (round insert) Flywheel Cover w/gasket Brake resevior cover Throttle Cover All parts are in good shape, have been in my garage for a couple years now. Parts are available separately or take them all. Can get pictures if needed. MAKE OFFER........ Thanks for looking
  12. Sorry no pictures yet..... Air box is in mint condition, comes with stock filter, lid and snorkel.
  13. For sale..... Stock Air Box off an 03 shee. Can get pictures if needed. Respond to post or email me at: SHMECKEL45@aol.com Has been sitting in my garage for years..... MAKE AN OFFER!!!! Please take into consideration shipping costs.... I am in zip code 48083. Thanks for looking.
  14. 203 views and no major responses.... any suggestions, questions, comments...??????? Still for sale.......
  15. I have this one..... I'll see what else I have. I will get better pics of the bike tonight or tommorow.
  16. FOR SALE: Drag Banshee, running on METHANOL J-arm frame, painted black w/custom built subframe +12 swingarm Stock jugs ported and polished, welded crank, CPI in-frame pipes Lockout clutch, override trans Holeshot HD's for dirt, 22" Skat Trak (12 or 14) paddles for sand, and Slicks for the track Blue plastics.... front and rear fenders have been cut, no headlights, no front brakes. Only about 5 gallons of Methanol have been run through the bike since the last rebuild. Bike is located in Las Vegas, asking $5000 OBO, willing to deliver depending on distance. Pictures available soon. Reply to post or email SHMECKEL45@aol.com with any questions. Thanks for looking.
  17. banshdog
    Big Bear Carb
    Looking for a carb for a 1999 Yamaha Big Bear 450. Thanks.
  18. You got it....... lee h....... PM sent.
  19. BRAND NEW Powr-Quip, deisel generator, 6500 watt. $1000 OBO
  20. Prices as noted - - - O.B.O. Hilti core drill DD100 (Like new) - $2200 Hilti TE16 Hammer drill (Brand new) - $450 Hilti GX100 gas pin gun/steel framing nailer - $350 Pallet Jack - $200 Drywall Cart - $200 Hilti deck gun (Brand New) - $200 Puma gas air compressor (Like new) - $650
  21. May be interested in the fronts...... PM me with price.
