Dunedemon, question for you. My "spring" knowledge is fairly limited. The shocks actually felt really good, softer but soaked up everything through 3rd and 4th, however, I didn't hit anything really big, just some moderate stuff. The problem that I know will come is like in the whoops, I'm sure there isn't going to be enough rebound to let me take it at speed. The question I want to ask you, and anybody else who can answer is, how much difference is there going to be between 285lb springs and 300lb springs? Before, it was definitely stiffer, but at speed it handled pretty good, probably could've used it a touch softer, is the added 15lbs going to tighten it up A LOT, or just some, but not a shitload. Also, he's just sending the main spring, so the small spring will still kinda be softer, so it'll probably still soak up the high speed straights a little better and the stiffer spring will hopefully be enough for the necessary rebound and all, I guess.
The difference will be noticable but not HUGE, it helps to think of the change in a persentage. 15 lbs is enough aparently based on their valving and how the lonestars position the shocks (I assume Elka takes this into consideration when suggesting rate / valving changes) never the less, I imagine you'll be in good shape. It's important to keep in mind that although that spring is longer than the other one or two above it, it is the softest (rate) spring of the bunch, thus it greatly affects the "initial" spring rate but the "final" spring rate (controlled by the upper smaller spring(s)) remains un changed....Make sense???
BTW -8 deg of camber is a LOT, I prefer -3 to-4 myself, Galfer lines are great, you'll be hapy with them.
