10
Everything posted by camatv
2010 BansheeHQ Ride Little Sahara, OK in October
camatv replied to locogato11283's topic in Riding and Events Forum
Banshee's ---------------------------------------------------------------- Stock Stroke Cub M&M 4mm Cub M&M 10mm Cub M&M 4mm DM M&M 10mm DM M&M 4mm DMX M&M 4mil cub - FAST (wheelsmanslim) 4mil cub - FAST (Badassbanshee479) 4mil cub - McCoy (RadarRacing) 10mil cub - McCoy (Boo_69) 10mil super cub - Titan Racing (Badassbanshee479) 14mil DM - McCoy (Fouledout421) FAST 4mil - (runDMC) 688cc dm 10mil Twister (alcoholbanshee) 10mil cub - Redline stock stroke/cylinder - HJR - Springer 4mm cub F.A.S.T - Quaddad817 stoke stroke/cylinder-Flotek - TNT 4mm Stk Cyl HJR Spurdy 4mm Cub M&M 4mm Cheetah M&M 4mm Cub M&M 4mm Cub M&M 4mm Supercub M&M 350 stock cylinder/stroke ????? BBIII stock cylinder/stroke-H2OLDS 10 mill cheeta (CAMATV, self built) 4 mill cheeta ( CAMATV, self built) 350cc SS, SB yfz chassis?? ( CAMATV self built) Other Bikes: -------------------------------------- golf cart & pitbike - magz yfz450 - magz kfx700 -magz YFZ450 Stock- Dallas Pimped Blaster 240 - Dallas another pimped blaster-H2OLDS cr500 trike ( CAMATV, self built) ATC 70 pit bike ( CAMATV, craigslist special) ah ha man wish i had a golf cart. i dont have a shop affiliation. but i do refer to F.A.S.T. AND M+M for parts on builds as i dont have a dealer/ shop tho that might change some time soon.. unless i find another job!> -
buy a new shift shaft, and clutch gasket and 2 qts oil, and might as well change the detent , alignment guide pin and spring while your in there. oh and you will need the clutch lock washer also.
YIKES!! in my opinon the stock baskets limit to HP holding is about 55-65 hp. you dump the clutch hard on paddles nad your going to snap fingers off.. of course the weak part of hinson + wiseco baskets is the bolts that hold the weak plate on. kinda sucks the stock oem backing plate is STUPID hard and wont flex BUT the basket itself is crappy, the aftermarket basket is strong but the backing plate is junk. there are many aftermarket baskets available now that have this backing plate issue resolved.. i still prefer the straight cut spring loaded basket on the higher hp motors..
make sure the impeller is working ( pop cap, rev bike, look for coolant wooshing around), replace your cap, 13-16psi is available at o,reilley's ( its an import cap) do you have actual coolant in there like 50/50 mix right out of the bottle? or straight water out the tap ( big no no) THEN make sure your radiator is CLEAN that is NO mud or dirt or crap in the rad finn's is your grill stock or one of those aftermarket ones that you cannot even see the rad? wash it out with water and LET it dry before you ride it in the woods. if the finns are bent bad you might try and straighten them. you can't really just put put a bike like this in 1st gear or so. there is no fan and they can get pretty hot due to the lack of flow. the 16psi cap might solve the issue also. IF everything else is ok.
Coolant leak from case stud after assembly
camatv replied to Valin's topic in Banshee Repairs and Mods
i always smear ultra grey on the clutch cover on that part i think it does a few things i think it helps theo-ring slip into the clover and helps seal ANY small leaks that might develop. the NEW o-rings is a weird size anything other than the factory yamaha o-ring seemed to not work right for me. would always endup leaking, ear on install, or seap into the trans area. -
Parting out my dunner 404 vitos, +4 swinger
camatv replied to TexasBansheeMan's topic in For Sale - Parts & Accessories
i have stock a-arms./ if you think you might still sell it complete let me or kickstart know. -
ole spurd's ride is about as close to a "dunner/ dragger" as i have ever seen!> hell the old fart ( HA) won a couple classes by blasting his " drag bike" through about a mile of whoops! m+m's bikes just show what good dune support gets ya! what i cannot get added to the list? does self made not count? or am i the only one HA -
how about adding actual motor size a 4 mill dm and a 4 mill cub arent even close in cc size HA how abuout add me to the list,. probably have 350cc stock cylinder ( maybe.) 10 mill cheeta ( 535) 4 mill cheeta ( 485) not sure if i'm consider'd a builder. but i built all my own motors. had help with domes but thats it. -
is this bike still altogether?? i cannot believe that you couldnt sell it all together. -
it seems everyone in the area here threw their stock pipes away one guy dosent want to sell his????? after buying t-5's of course i'm not paying 100 bucks for a set either. and ebay is litter'd with them do they EVER actaully sell those things? i mean really 49 bucks for ONE pipe and 35+ bucks for ONE silencers. what the hell.. i can cut them and mod them no problem right now its just finding a set!? i'd even take pics of everything.
2001 banshee 404 big bore Vito's
wow i cannot believe you cant sell this bike. this is a no brainer .. -
what are those caps on the front hubs? those look cool..
yea we are all riding japanese built bike's. its the chinese "get rich quick junk" thats screwing up our stuff you can cut your stock timing plate for +4 d timing anyways.
i cant believe how many times i heard that a 115 rod crank was a 5 mill stroker.. back when i was doing the long rod 350's for mx use. but now in all reality i like the short rod motors in the smaller cc. longer rod is just that a longer rod to get a stroker yo have to move the pin around.
i sure like my trinity's
well i guess i am a lil baiased on the pipes the trinity's i have are actually on a highly modded 421 stock cylinder motor that makes around 55+ft lbs of tq. and around 80hp. its pretty hard to ride at times. the PC's are a great overall pipe. BUT for woods the t-6 gets my vote. plus they look amazing in my opinion. pc's are easy to find used.
i looked at that pic again i think the guy right behind the driver is waving the stank of that old guy driving with no shirt on in the heat's ole guy BO! he's definatelly not waving for the camers its nore of a oh man whats that stink!! i should have sat in the back seat!!
thats great thats the picture i was looking for the ones i am looking at are NOT rockets then not sure what they are tho. hmm. is that the rocket car you ride in to go to the dunes? HAHA
those are some nice looking bikes! WHAT FRAME is that green and blue one? hows it ride? looks cool. that read and black bike in the earlier posts is an outlaw chassis. you wouldnt happen to have any pics of that air box do ya?
sticky?
the toomey needles should work very well. last 421 i did with stock carbs i ended up in the 400+ main range also. think it was at 430? but a lil bigger cc than yours. they actually run very suprisingly well with stock carbs. but 35's work much better! just goes to show how much mikuni carbs rely on needle and main jet for jetting and not so much on the pilot. that nearly the same pilot size as stock BUT HUGE main jet. that's the reason i believe so many people like them so much.
dang jenn's bike needs an axle.
good luck i cannot seem to even get 6500 out of my lsr full framed cheeta.
20 bucks shipped?
