I am toying with the idea of parting out this bike instead of selling it as a whole. There are literally about 10 minutes total of test time on all of these parts. Everything is basically new.
Here are the parts that I will be selling:
Motor: 421cc Cheetah - 68mm bore Polished Cheetah Powervalve cylinders, 23cc pump gas domes, and 19cc domes for 110 octane race fuel, Polished Cheetah head cover, 4mm Hotrods stroker longrod crankshaft, Chariot Racing billet intakes, V-Force 3 reeds, adjustable stator plate, billet water pump impeller, billet 3 piece stator cover, billet water cover, chrome clutch cover insert, Tusk racing clutch with HD springs, billet oil dipstick, powdercoated wet black kicker, clutch cover, and motor mounts - $3200
Pipes: chrome original in frame Rocket pipes with billet exhaust clamps - no dents or scratches, polished silencers - $450
YFZ450 front a-arms, polished aluminum upper arm, powder coated lower arm, YFZ450 spindles and rotors, YFZ450 larger ball joints, extended steering rods, Elka Duner front YFZ450 shocks - $600
Keihin 35mm PWK carburetors, Chariot Racing billet float bowls, throttle cable, K&N Filters with outerwears - $500
Laker custom black front and rear fenders - $400
complete set of Maxxis Razr 2 tires on stock wheels - $350
Billet Pingel dual outlet fuel valve with screen - $75
Billet front and rear exhaust hangers - $40
Billet JDS tribal flame front grille - $55
Billet gas cap and blue breather hose - $40
Throttle block with billet cover - $40
ODI lock-on grips - $20
Billet rear brake reservoir and cap - $50
Braided stainless steel front and rear brake lines (works on up to +2 front ends, and +4 swingers) - $70
Yamaha R1 rear master cylinder, polished lettering - $60
Renthal handlebars and pad - powdercoated wet black - $25
Billet handlebar clamp - $20
ASV black clutch lever - $75
Chrome Tarantula racing rear grab bar - $80
Billet R.I.S. designs front bumper - $130
Chrome Trailtech headlights - $90
Yamaha R6 LED rear tail light - $40
polished aluminum nerf bars with black nets - $100
4" extended swingarm, stock carrier with new bearings, seals - both powdercoated wet black - $175
Stock rear shock, polished ressie, wet black powdercoated spring - $100
rear hubs, brake hub with rotor, and sprocket hub with stock sprocket - powdercoated red - $60
Modquad complete black chain guide set - $60
D.I.D. gold x-ring chain for longer swingarm - $75
chrome Geforce adjustable +4" rear axle - $160
All parts will include AlloyBoltz polished mounting nuts / bolts / washers, where applicable.
If the big stuff does not sell, the bike will not be parted out.
These pictures should just about cover everything:
