What is the application?
Drag, trail, etc.
On a drag bike, its virtually inevitable that you will be wrenching on it, so ATF has always been my go to because its cheap and works fine. If its a daily rider, duner, trail type deal where you just want to add gas and ride, then I would recommend a Redline, or something along those lines.
What gender neutral shifting juice does ary body recommend?
The gender fluid fluid of choice is tranny oil.
I use Rotella T6 5w-40. Cheap enough and works well for a play bike.
