ric-ross1
    5
Everything posted by ric-ross1
  1. Pmd. Sent from my iPhone using Tapatalk
  2. What condition are the shocks in? Sent from my iPhone using Tapatalk
  3. Olive oil extra virgin is my choice, nice and smooth! Sent from my iPhone using Tapatalk
  4. It was the last wire I had left from a long time ago, but I can tell you that it wasn’t thick, what’s the size are you supposed to use? Sent from my iPhone using Tapatalk
  5. If you still have them PayPal ready.
  6. I already installed the o rings on the head and torqued it down but motor hasn’t been ran, I should be ok or do I need new o rings? Yes, everything was supplied by the builder. Sent from my iPhone using Tapatalk
  7. Is it not safe to run? Sent from my iPhone using Tapatalk
  8. I didn’t like the numbers but builder said to run it, I finished putting the head on yesterday so I have a leak down test next, as far as compression test I won’t be able to get once for a few weeks due to the frame being gone for powder. Sent from my iPhone using Tapatalk
  9. As per the builder I’m ok to run it. Gusto I already paid for those cut domes for the build.
  10. The gasket set provided by builder. Driveline cool head. I will, J tried today but I’m sure they are busy with the Holliday’s. Thanks, trying to be done with putting it together and set it aside while I build frame. Might need more solder wire lol.
  11. Got to put the motor together 4mil, did a squish test and I got 1.16mm and 1.06m, it’s got 23 4 mil domes which were sent by the builder for a pump gas set up. That numbers seems wrong.
  12. T5 still available?
  13. that but I’m pretty sure it’s supposed to go on the outside not the inside lol. Sent from my iPhone using Tapatalk
  14. After some more digging I came to the conclusion that it’s a driveline head but they don’t make them anymore... Sent from my iPhone using Tapatalk
  15. I'm looking for the 2 bolts that go from the motor mounts to the bottom of the cases.
  16. Sent from my iPhone using Tapatalk
  17. Thanks for the info guys, I’m looking to build a 4mil this winter so i wanted to see if i needed a new head or that one would suffice. Sent from my iPhone using Tapatalk
  18. Usually quality stuff has a engraving or stamp somewhere but this head has absolutely nothing. I have some of those going in before next ride. Sent from my iPhone using Tapatalk
  19. Bought a quad and it came with this head which to me it looks like a cheap one, going to build a 4 mil and wanted to see if I need to ditch this head, no markings on it whatsoever. Sent from my iPhone using Tapatalk
  20. Here is the other side. Sent from my iPhone using Tapatalk
  21. Got the bike last week and going through everything and noticed the tires are ate up on the inside, went to adjust camber but the nut is only hanging on by a few threads. Sent from my iPhone using Tapatalk
  22. I did. Thanks Sent from my iPhone using Tapatalk
  23. Wtb oem ignition coil. PayPal ready. Sent from my iPhone using Tapatalk
  24. How are you going to post this and provide no pictures? Condition would say a lot about the value.
  25. I know it sucks but for a 500 project that runs take it apart, fix it right and be on done with it, no worrying about it anymore. Sent from my iPhone using Tapatalk
