On my 04 Banshee (with a 7mm stroker) What would be the "safe zone" for rpm's (where I shouldn't go below or above), what would be the absolute max rpm's I could hit (safely and unsafely), and, at about what rpm's would I start and end powerband? Remember, it has a 7mm stroker kit. Thank you for your help.
Common sense says don't go below 0 rpm or above 12K rpm
I'm assuming he is talking about mean piston speed which increases a stroke increases.
From the 2 stroke tuners handbook, the normal max MPS is around 4000 ft/minute
MPS=.166*stroke (inches)*RPM   which puts the normal max rpm for a +7mm around 10,500.
BUT, Not very many people get on here talking about snapping rods and over that RPM you are in over-rev and should shift anyways.
Basically don't be a dumbass and rev it to 12K for 5 minutes at a time.
