just put a fresh stock bore top end on my 98 banshee with wiscos and rebuilt both carbs, stock everything. runs great when first started up then left cylinder putters out, overflow from carb starts leaking until you tap the side of the bowl then it stops and runs great for a little bit, I figured the float was sticking but I took it apart numerous times and it isn't, its all perfectly clean and new internally. sometimes it will die out with no gas coming from overflow, then tap the carb and its fine again. help
