BenBB
Everything posted by BenBB
  1. In order: 1. BHQ :tongue: 2. RockymountainATV :thumb: 3. Fleabay :baseball_shifty: 4. Everywhere else; some decent prices on OEM stuff (like for th RZ motor) at www.powerpartsplus.com, or sometimes I'll buy direct from Toomey or Works or whatever...
  2. Oh great my '01 Silverado just turned 155,000 :baseball_getlost: ...my work truck is a '00 Z71 with almost 260,000 and we haven't been in the tranny at all... On a side note, they FINALLY put a damn drain plug in the tranny pan, woofuckinghooo!!
  3. Yup, have a good one wherever you're at Wheatie :beer:
  4. True but the one with the couches around the hooka is just classic...
  5. Hell I was gonna do it anyway, bail or no bail. Flag burning is right up there with child molestation and wife beating as far as I'm concerned, fucking dumbass cowards got it comin'...
  6. Beware of my son on Halo 2, "Mista M0dd3r" heh. My account ghostrider57 got banned from ranked games on Halo 2 when we put soft mods on the old box (a few too many killaminjaros), I don't get on much with that one but my stepson does. Ghost Recon Advanced Warfighter and Battlefield 2 mostly, Need For Speed Most Wanted and Perfect Dark Zero sometimes. I'm pissed the HDD on my 360 took a shit. Apparently I'm stuck buying a $100 MS drive, even though it's just a 2.5" SATA like a notebook uses, but nooooo there's some proprietary firmware bullshit on it. It wouldn't matter except ya gotta have the hard drive to store Halo 2's maps, and software emulator, and the damn Live account info(?). WTF is up with the rumors that Halo 3 is out in a couple months??? I think not, Gears of War keeps getting pushed back farther and farther too...
  7. Yeah same here, when is that? Just out of morbid curiousity of course...
  8. Yep I'm about 2 hours East in Roswell. There's a couple great places to ride, Red Sands just South of Alamo on 54 has miles of sandy trails, lotsa whoops too. In Februrary they race the Tarantula 100 there. Supposedly there's an MX track in Alamogordo but I haven't been to it, just to the North is Tularosa, I used to race TT & MX there but they took out the TT track a few years ago and I haven't been back. The dunes in Kermit, TX aren't too far away either...
  9. Damn fast shipping too heh, thanks again Kai!! :thumb:
  10. Guess it works both ways heh, found "this thread" at the Yamaha RD forum, gonna hafta post a pic there of my own conversion heh.
  11. Hell yeah great to hear man, if it wasn't 1500 miles away I'd be there!!! Take it easy :beer:
  12. Just reverse the rear wheels, that'll get you pretty close to +2...
  13. UPS says the clutch will be there Monday 6/26...
  14. I couldn't find the mainshaft small bearing and the countershaft small bearing, or any manufacturer numbers on 'em when I had mine apart so you might be stuck with Yamaha there (so far Power Parts Plus has had the best OEM prices I've found). But you can go to a bearing store to get the other two bearings, just make sure they are good quality German or Japanese and not from China or Taiwan: Mainshaft big bearing - Koyo 83427 Countershaft big bearing - NSK 6305N/6305a5 You might have better luck than I did having them matched up, but if it helps the metric dimensions on the other two are: Mainshaft small bearing - 21x30 Countershaft small bearing - 21x33
  15. It's pretty straightforward, just takes some time & effort, and you never know when you'll run into a snag (like a pivot bolt rusted to the spacer, or axle rusted to the spacer...). Remove the left rear wheel and hub, remove the axle nuts, pull of the rear brake caliper (just let it hang by the brake line so you won't have to bleed it), and remove the chain, then slide the sprocket hub off. If your swingarm is stock and you're going to -2 you're gonna hafta shorten the chain anyway. Slide (hopefully) the axle to the right out of the carrier, if it's a bitch you'll have to work at it, just be careful not to pound on the end of the axle or you'll crush the holes for the hub castle nut or trash the threads, you may need a short piece of pipe to drive against the axle where it necks down for the hub. If it doesn't slide right out soak it with some kind of penetrating oil and let it sit a day or two. Worst case you'll need to dismount the whole carrier and mount it in a vise or something to drive the axle out or worse yet use heat on it to get it to break loose. Leave the brake hub on the axle and set it aside. Remove the swingarm skidplate if you have one and are gonna reuse it. Remove the rear shock linkage bolt where it mounts to the swingarm, and the lower rear shock mounting bolt. Let the shock hang by the upper mount and let the linkage drop down out of the way. Remove the swingarm pivot bolt. Here again it might be a bitch as the sleeve will rust to the bolt. Try soaking the shit out of the bolt first with penetrating oil, then driving it out carefully without messing up the threads, when all else fails use heat and force. Once it's out installation is the reverse of removal; pivot bolt, lower shock bolt, linkage bolt, axle in carrier, sprocket hub, axle nuts, hub & nut & cotter pin, wheel. Going back together, if possible use an impact wrench on the hub nut, that little bastard likes to work loose. Use hi-temp or lithium grease on the pivot bolt and shock/linkage bolts when going back together; hi-temp if you don't ride in water, waterproof grease if you do ride in water. I use red loctite on both the pivot bolt nut and the axle nuts, never-sieze on the axle splines for the brake, sprocket and wheel hubs. Check the chain slack and adjust (ugh) if necessary, I use blue loctite on the stock adjuster bolts/nuts and the carrier nuts. While you've got the whole ass end apart there's a few things you can do if you want to: 1. If your rear shock squeaks like a bitch when it compresses, pull the whole shock off and grease the spherical bearings real well, and make sure the seals are pointed the right direction (I've done two that the seal lips are facing the wrong way). 2. Replace the stock piece of shit swingarm chain slider. I like T.M. Designworks, there's others available from Cascade, UPP, etc. Anything is better than the stock donut. 3. Check the pivot bearings; in this case they are prolly ok since it's a new(?) swingarm. Check the pivot seals too. 4. Replace the axle bearings & seals; preventative maintenence but here again on a new one not necessary. 5. Add a grease zerk on the pivot bolt. Some (not many) aftermarket swingarms will have a grease zerk for the pivot bolt, if not either drill & tap one on the swingarm or do what I did; weld the head end of the hollow pivot bolt shut, cross-drill the bolt and the spacer (1/8" or so holes), and find a drive-in zerk that fits the thread end of the bolt tight. Fill it with grease and put a couple shots in it every once in a while. 6. Add a grease zerk on the axle carrier. New round housing should already have it, if not or if it's stock, drill & tap the carrier for a grease zerk. Don't forget to pry off the inner seals of the axle bearings so grease can actually get to them. 7. Inspect the axle splines for wear, or better yet take the opportunity to upgrade to an aftermarket axle, it's worth it. I have had great luck with Lonestar and highly recommend them, but do a little research on others and find one you like. 8. Inspect/adjust/rebuild rear shock. Maybe send it off to Works for a heart transplant or someone else to be rebuilt or revalved (Janssen, Axis, etc.). Check for leaks while you're in there and get it done while you've got everything apart already. 9. Replace the chain & sprockets (as a set). If they're worn now is a good time to get it done. I've had good luck with DID o-ring chains and cheap sprockets, I upgraded to Sidewinder Ti chain & Tri-metal sprockets and they are holding up great. 10. Check the rear brake pads & rotor. If the rotor is warped replace it (Galfer and others make damn nice wave rotors). Same goes for the pads. While you're at it drain and replace the brake fluid, it WILL make a difference on an older machine, as will upgrading to a stainless steel brake line (have fun bleedin' it tho heh-a Mityvac is invaluable). Did I miss anything?
  16. I'm looking for the little couplers with the o-ring, where the pipes mount to the cylinders. Anybody got some stock pipes you could cut those couplers off of??? My PT Revs don't have an o-ring just a female coupler...naturally it leaks, if I can find the o-ring coupler I can weld them on in place...
  17. Have a good one dads!! :cool:
  18. I suspected as much, if only I had the green!!! No shit a crf50 quad?! That sounds so cool, wicked 'lil pitbike hehe :thumb:
  19. I can't find a web site for Leager anywhere, and LSR doesn't have much anymore for Banshees or Raptors, it's all fucking 450 shit :: They don't even list an Outlaw Banshee frame anymore, or any frame for a Raptor, but there's complete frames, subframes, and gusset kits for YFZ450's. I just found a nasty crack on my left footpeg mount too :sad:
  20. Those Fox float shocks are pretty sweet, light weight and easy to adjust. A guy had them on a YFZ and Chris (ridingorhiding) rode it and said they were smoother than anything he's ridden (he runs triple or quad rate Elkas on Janssen LT arms), I didn't try them myself and don't know how well they hold up in the long run, but I would take a serious look at 'em...
  21. BenBB
    idle screw tap
    I've got the tap too if ya still need it, but I wouldn't suggest sending it in the mail in a regular envelope; somebody sent me some pilot jets and the postal machines ate 'em heh. I can ship UPS free from work tho, lemme know...
  22. I've got a complete clutch out of my '96; basket (some wear but well within spec), all the plates & stock cushions, pressure plate w/adjuster, rod, ball. Also one of those pancake bearing & adjusters but I never could get it to work right...any parts to trade or want to make an offer?
  23. Just curious, and I know somebody's gonna ask anyway, but where are you located? And what would you take for the Banshee alone?
  24. Haha no way! Road trip!! Ok I'm puttin' in $107.76 :happy:
  25. Right on bigwill, here's hopin' for a full and fast recovery, take care.
