Rodneya
Everything posted by Rodneya
  1. What are drag cut rear wheels?
  2. Would you be able to perforate the tank stickers so that they can be used on the 5 gal tanks without peeling off?
  3. Try take some more pics, but from a bit further away so that the camera can focus properly. Or see if your camera has a macro setting for closeups. (There is sometimes a flower on the setting button for this.) It a bit hard to see what is going on up at the top of the intake.
  4. You need to find the cause of the meltdown before rebuilding or it will happen again. Air leaks, blocked jets or running the float bowls dry at WOT can cause this.
  5. I dont think new piston and rings will solve anything. The uneven running is most likely a problem with the carbs. What does the smoke smell like. You may just be running rich on 1 side, it could be a coolant/tranny oil leak.
  6. That is not from detonation, but preignition probably caused by an air leak. What does the other side piston and plug look like?
  7. No it will not hurt your motor, but using fancy coolants will hurt your wallet.
  8. 125 at sea level for a stock motor. readings much higher than that are probably from an inaccurate guage Below 90 to 100 is time for a rebuild, or if there is a big difference between sides. If both sides are 110 you are good for a while yet.
  9. What does ported to 65 mean? Are you running pods or airbox with/without lid and what is your elevation? I would say that on a ported motor with an open airbox close to sealevel you are lean on the main jet.
  10. A stock Banshee is 6.5:1 according to Yamaha, and will run on regular 87 with no problems.
  11. There are 2 rubbers and an aluminum spacer that go with each silencer. I think the only place to get them would be FMF.
  12. The Banshee motor is the same from 87 to 2010. It has not changed, so banshee pipes will fit any year.
  13. Warm them up with a heat gun. The goo will come off with the sticker. Just dont make them too hot.
  14. No, if you take the fuel petcock off the tank you will see that there is a filter in there. It gets blocked fairly easily. I would loose the inline filter as they often cause problems even if they look clean and flow well when you test them. Are you sure that you are jetted right.
  15. Check the filter in the petcock is clean and that the breather in the cap is not blocked. Either of those will screw with the fuel flow.
  16. Its the stupidity factor. A lot of people think louder is faster
  17. Try living in Vancouver. All it does is rain all winter long.
  18. $27.76 $19.99 $24.95 2 minutes on Google u ignorant fuck
  19. Rings are like $30 from a dealer. If you are looking to save money with used rings you need a new hobby. Whats next? Home made gaskets from cereal boxes.
  20. Rodneya
    If my wife
    Now that is pretty funny
  21. Pilot jets may be too small or clogged. take em out so you can look through them and check they are clean. Also check that the tube is on between the carbs and that the slides are in the correct way - cutout facing the air filter.
  22. Look at the pictures, there are no TORS. You can see the carb cap in the second pic. Try going bigger on the main, and get the clutch together so you can do plug chops to check jetting.
  23. Rodneya
    100 Mph Banshee
    My link So, if you were wondering how to go 100 Mph, you jest need a pipe made out of old lawn chairs and duct tape.
  24. did you re-torque your head after the heat cycles?
