hi all i have a 05 shee that i just put together. 370cc wiseco pro lite pistons with stock stroke, weld crank. my mods are case port and mach my cylinders open up the runners. open my exhaust to 84 for better exhaust flow. flywheel mod as well.
i will say my porting is a race - drag portting, mill stock head and re-chamber got me 185psi compression. i am +5 on my timeing running 40-1 pre mis 110 octane
here my problem , haveing a hard time jetting my 34pj current set up is 160 main and 58 pilot air screw 1.5 turns out on both carbs.
as for the needle is on the middle clip,needle type i have no idea it has a letter j ,waiting for my cgl needle to come in. the bike has a realy bad gog on the botton end mid to top real good. i need a good staring point. this is my fist time i worked with bigger carbs set up, before i had stock carbs with 390 mains and 30 pilots 1.75 turns out it pull nice as for my elevation am at 1200 feet to sea level, glamis ca
