hercalmighty
Everything posted by hercalmighty
  1. Are you getting oem or aftermarket Sent from my VS990 using Tapatalk
  2. Try flipping your rims around and see how it feels. Since the center line of your wheel is so far from the center line of the spindle it will feel weird. I have +3 arms myself. When I had the standard 3/2 rims it felt heavy steering. Got 4/1 rims and it feels so much better Sent from my VS990 using Tapatalk
  3. https://philadelphia.craigslist.org/snw/5698990530.html Is this your cl ad Sent from my VS990 using Tapatalk
  4. That's a good idea too Sent from my VS990 using Tapatalk
  5. Honestly once they start to peel they are done. Pretty much only option is to pull it off and either leave it off or get a new one Sent from my VS990 using Tapatalk
  6. Stupid question. Did you remember to take the shrader valve out of the pressure gauge? Sent from my VS990 using Tapatalk
  7. Where are you located? Sent from my VS990 using Tapatalk
  8. You really need to know what size dome you have. You also need to check your squish. Cranking compression isn't going to tell you what fuel to run. You have to figure out your copression ratio Sent from my VS990 using Tapatalk
  9. What pilots are you running? What needle and clip position? What is your compression? Are you sure the carbs are 38mm non Airstrikers? Regular PWKs go 35mm and 39mm. Airstrikers are 35mm and 38mm. Sent from my VS990 using Tapatalk
  10. What size domes? Have you checked your squish? If you have trinity domes, you might need to get yourself some new domes. You might not need 110 octane. Are your carbs Airstrikers? What size pilot do you have? Check and see if your pv's open all the way up. You might need to cut them to match the roof of the exhaust port when they are fully open. Sent from my VS990 using Tapatalk
  11. Can you answer the questions? Sent from my VS990 using Tapatalk
  12. What size motor? Pipes, carbs, jetting, fuel, mix, etc? Sent from my VS990 using Tapatalk
  13. Pipes, carbs, jets, domes, fuel, mix, elevation? Sent from my VS990 using Tapatalk
  14. Ahhhh, yeah. Sent from my VS990 using Tapatalk
  15. Are you serious? Sent from my VS990 using Tapatalk
  16. Does it run better with the bigger mains? What size pilots do you have? Sent from my VS990 using Tapatalk
  17. Ok. Have you checked the clutch? Maybe it's slipping? What do your plugs look like? Sent from my VS990 using Tapatalk
  18. Ok. Still doesn't answer my question. Is the motor reving out? Sent from my VS990 using Tapatalk
  19. What do you mean by it makes a lot of noise but doesn't go any where? Are you saying the motor revs out but the quad doesn't move or that the motor doesn't rev out Sent from my VS990 using Tapatalk
  20. Oh ok. I live right off the lansdale exit of the northeast extension Sent from my VS990 using Tapatalk
  21. Where at in PA Sent from my VS990 using Tapatalk
  22. Bought a TM Desigworks chain slider from Ron. Shipped it out within an hour of sending payment. Came just like the pics and with a FAST cozy lol. Great dude. Thanks again Sent from my VS990 using Tapatalk
  23. Tricked, do you know what the roll design swing arm weighs? I just ordered a fireball hd swingarm in stock length and shipping weight is 14 pounds. Just to give you an idea Sent from my VS990 using Tapatalk
  24. If you are that far off, take a measurement from the frame to center point of each ball joint. Compare side to side. See if everything matches up. As just for shits and giggles are all your rims on the right way? If you have one rim flipped it will throw everything off Sent from my VS990 using Tapatalk
  25. What arms are you running? Are they adjustable? If so, how did you set it up? Sent from my VS990 using Tapatalk
