hercalmighty
Everything posted by hercalmighty
  1. We're the bikes in a shed or in a garage? Sent from my VS990 using Tapatalk
  2. Just saw on FB that Fireball has new long travel arms that are more like the other brand full wing style arms Sent from my VS990 using Tapatalk
  3. To add to tfaith's post. I bought+3+1 arms from fireball and had 3/2 rims. It handled like a lack truck. Bought 4/1 rims and it made a huge difference. Sent from my VS990 using Tapatalk
  4. Slomo, are you running a plate for the 4mil or are the domes cut for a 4mil? When I had my 4mil stock jug with cut domes I had 20cc domes and was pushing around 180-185 psi. Then I went to 23cc domes and was pushing around 160-165 psi. Sent from my VS990 using Tapatalk
  5. Do a leak down also before you open anything up Sent from my VS990 using Tapatalk
  6. 125 psi? Either you have a bad tester or something is screwed up. Did you check your squish? Sent from my VS990 using Tapatalk
  7. Have you done a leak down test? Sent from my VS990 using Tapatalk
  8. Well that's kind of the thing with powervalves. When the powervalves are down they mimic a low port and when they open they mimic a high port. When you drag port a cheetah you will lose some bottom but it's not like drag porting a serval. Your "metaphor" of PC's on a cub is way different. The Cub has fixed port timing set for a "drag" pipe. Putting a "woods" pipe on is just choking the motor Sent from my VS990 using Tapatalk
  9. Do you have any idea how powervalves work? A drag ported cheetah is not like PC pipes on a cub at all Sent from my VS990 using Tapatalk
  10. Need to know what jets are in it Sent from my VS990 using Tapatalk
  11. Exactly Sent from my VS990 using Tapatalk
  12. It seems like the people who actually go to his place and pick out their stuff are happy. EBay people not so much Sent from my VS990 using Tapatalk
  13. Did you go back to 91 octane? Sent from my VS990 using Tapatalk
  14. Thanks Spurdy. Sent from my VS990 using Tapatalk
  15. Ok. Just looked at the bolts. They are 12.9 bolts. So just tighten the hell out of them or is there a torque I should go by. If it matters it has 4 pinch bolts. Sent from my VS990 using Tapatalk
  16. I'll have to look Sent from my VS990 using Tapatalk
  17. The bolts and nuts fireball sent with the arm Sent from my VS990 using Tapatalk
  18. Yes. They have the nylon Sent from my VS990 using Tapatalk
  19. Stupid question. I'm installing my first roundhouse swing arm. What should I torque the pinch bolts to? Thanks Sent from my VS990 using Tapatalk
  20. Are the domes from trinity? Did you do a squish test? You said no air leaks. Did you do a leak down test? Sent from my VS990 using Tapatalk
  21. So far I like. Since that pic I have switched to 4/1 rims Sent from my VS990 using Tapatalk
  22. Fireball +3+1 with elkas Sent from my VS990 using Tapatalk
  23. I hope so lol. Sent from my VS990 using Tapatalk
  24. Holy hell! $450????? Sent from my VS990 using Tapatalk
  25. Lol. I was just wondering. I thought he said he was looking to do all types of riding. Then he posted a pic of a dune/drag frame. Sent from my VS990 using Tapatalk
