james97gt
    1998 banshee with 472 cheetah with powervalves cpi small bore 38 mm keihn carbs lock out
james97gt's Achievements
  1. Does anyone know what the compression should be ? Stock cheetah head
  2. I checked my compression yesterday on my 472 cheetah and realized I only have 150 psi. I have been running it on 110 renegade . Can I run this on 93 octane ?
  3. Stock cdi stock stater lightened fly wheel. I checked the compression only has 150 I assume it has stock cheetah domes does this sound right ?
  4. 38 mm pwk non air striker
  5. It idles great and cleans up when you get on it plugs look great. Jetting is good cranks on first kick can be intermittent at times dosent do it if you roll into throttle. It does not sounds fat or lean out .
  6. It was running great then bad . Runs hard in 3rd 4th 5th and 6th
  7. Stock cheetah domes with powervalves
  8. 472 cpi small bore 38 pwk 175 mains 110 renegade 32 to 1
  9. I posted on two threads sorry
  10. I posted on two threads sorry
  11. Sea level . Was running great with this setup
  12. Cpi small 175 cheeta stock domes 110 octane renegade gas 38 pwks 250 r v force 3 reeds
  13. I have also cleaned the power valves
