doorslammer
Everything posted by doorslammer
  1. hey guys im after a paddle for my 4 mill rz banshee. i plan on going to the dunes this year sometime so i dont want to buy a set of paddles for a trip i may not do again for a couple of years, but at home i can get to the beach via a gravel road and alot of what i ride on is soft and loamy. i was looking at those half paddles that scat trak sell or prowedges. would these be worth while, what size and how many paddles would suit my bike? or am i better off sticking with knobblies. what do people reccomend for tyres normal tyres for the sand? i dont like running anything heavy, so not 6ply etc. cheers Toby
  2. why did you remove the head in the first place? and what type of oil do you use? and dont clean them in the cylinders, i've never heard of such a stupid idea. remove the pistons and use a wirewheel/wire brush.
  3. im after some boots for the airbox and 28 pwk's, mine have split anyone know where to get them?
  4. good to see the site getting some well deserved attention. looks real good! i can email the full shots if interested
  5. heavy duty degreaser on all the oily spots, let it soak for 5 min, was off with a hose, spay engine pipes, chassis etc with silicon spray. its a dirtbike not a show piece. but i still clean it right up before a big event with soap and whatnot, anything over half an hour isnt worth it.
  6. are we supposed to be making a banner?
  7. you'll probably need M6x1 M8x1.25 i didnt think there were any 10mm threads on the chassis? my last build i made into a roller, suspension wheels radiator, then motor. put it together the opposite way it came apart.
  8. do you say this from experience? WSM make some damn good pistons, comparable to Pro-X
  9. ohwell, i will soon see for myself. just bought a set of herrmann +3+1 longtravel front end with elka elites. will see how it compares...
  10. http://www.modquad.com/catalog/product_info.php?products_id=1281&osCsid=f104180a282b7c87c9224784ef25df7e thats about as good as it gets, you can get one for the stator side as well
  11. low compression yes yea? didnt touch? shake your willie while looking? what colour powerbands? answered your own first question, get the barrel to a machine shop to see if they are within their limits, if so get them honed and get a new set of rings yea when you drain the coolant the radiator will become empty
  12. these must be as rare as rocking horse shit... or doesnt anyone want to ship to aus?
  13. still looking...
  14. anybody? TTT
  15. use loctite 567 or that permatex stuff http://img-asia.electrocomponents.com/images/R330394-91.jpg http://www.henkelna.com/cps/rde/xchg/henkel_us/hs.xsl/product-search-1554.htm?iname=Loctite%C2%AE+567%E2%84%A2+PST%C2%AE+Thread+Sealant&countryCode=us&BU=industrial&parentredDotUID=productfinder&redDotUID=0000000JBE put some on the threads, and wind them in with your fingers, dont torque them to anything, just so long as all the threads are in, then put the head on and torque the headnuts. OEM torque for the headnuts is like 22ft/lb's, not sure if its the same for the t-rex set-ups.
  16. hey buddy where abouts are you, im in wickham and have a flywheel puller you can borrow. no lights or anything sounds like the stator has crapped itself.
  17. thanks guys i have PT mids on there but was looking for more top end and got a set of dmc's, but after looking i found that most of the interference is at the adjuster for the cables, and because i got some cables made longer they also used a different adjuster which was longer and therefor made it pratically impossible to fit with out IMO too much work. so i've sold the DMC's and am now looking for some PT high revs...
  18. hey all after some PT highs in good condition, chromed and willing to ship to australia. let me know what you have
  19. hey all is there any guys with RZ motors in their banshee's running Pro Circuits, DMC's, Toomeys or FMF's? just wanted to know how they got them to fit if they can. cheers
  20. what shocks were you running on the +2 banshee arms and what are you running on the yfz ones now?
  21. hey guys i've been running the YFZ front end for a while now but was curious to know if anyone had gone over the geometry of the set-up. the reason im asking is because im ready to drop some coin on a set of shock but if a set of +2+1 or +3+1 standard travel banshee arms will give me a better smoother more consitant ride i would get a set of banshee arms and shocks rather then keep the 450 arms. so like i said, has anyone checked out the geometry and compaired it to a standard or long travel set of banshee arms? or has anyone switched from 450 arms back to + banshee arms and what do you think about them. cheers
  22. jump in line if he replys...
  23. the line comming from the top of the radiator under the radiator cap goes to the bottom of the overflow. The rear gearbox vent goes to the T connector. Out of the T connection one line goes to right side under the waterpump cover, while the other pipe from the T goes along the frame by the right exhaust chamber and hangs to the ground. The pipe from the top of the overflow bottle follows the other pipe down past the right exhaust chamber and to the ground as well. both of them are vents to relieve pressure
  24. my boss uses O2 sensors on his 100cc 2 stroke Karts and doesnt seem to have a problem. is a wideband and O2 sensor the same?
  25. i use a master gasket by locktite
