sleeper06
    20
  1. If you part her ill take the axle ,tires ,carrier,not optimal but it seems to be what everyone is doing
  2. You can go broke trying to save money
  3. I beat cubs with a stock cylinder,im not going to say anyday but im not scared to run head up with one
  4. I have a rigid chassis im building for a 421 cub,what wheel base woul you guys recomend,how far out back/front.I need to start welding this weekend but would like some opinions of what works as far as weight transfer is concerned,thanks.This is going to be a bike for 300ft dirt but I cant say its not going to see pavement,how long are you guys running your wheelie bars on dirt
  5. My motor is set up to run the 9 plugs ,been running them for two years or better on gas drag set-up,long hauls tho
  6. too rich with thet lid on,290 mains open box
  7. Thats a colder plug, that would give you a richer condition
  8. drop that pilot a couple sizes I think those carbs came with big pilots out the box
  9. No offense to anyone those jetting specs for stock porting sounds way rich,I was thinking with the lid on 260 in the winter 240 in the summer just been my experiance with these pipes
  10. Leave the stock pilot put a 240 main jet in with the lid on,put you needles in a richer position,stock needle
  11. An aggressive dune drag can run all the way up to 420s on the main,you need to find out the durations of your porting so you know what your dealing with one mans porting is diffrent from anothers
  12. I run .oo3 on wisecos,look on the package check ring gap,but there is a reason that skirt cracked,out of round cylinder,collapsed skirt from piston cocking in bore,I would pull it down again find some one with a bore guage and check it good
  13. Make sure you seal the keyway on the primary drive gear,washer/threads too,commonly overlooked but i have seen leaks in a few motors
  14. No worries bro 1-4 5th 6th clutch incase you want your 6th gear nuetral stock position,Extreme dunable .If it breaks in the weather ill dust my bike off and you can give it a try ,well going to work now
  15. Cutting the skirt on the intake side increases the duration of intake open period,unless you have a bg stroke or porting thaT calls for it you could hurt performance
  16. I had a 4mil trail bike that was 66mm ported and beatin for three years with no problems,maintaining only things that broke while riding,keep in mind if you do go bigger than .080 over(66mm) the domes need to be cut if your running a cool head
  17. With those duration with that pipe on a tight motor,no leaks you should be at a 320 main,27.5 pilot needle one notch on the lean side.Ohm out your plug caps,coil,stator
  18. ported ,not ported what size pilot is in there now,what needle,timing,compression,reeds,more info and we will be able to help
  19. I agree with loco,I have never jetted 28s but I have jetted 30s like yours drop the pilot,start at a 300 main with no port work,if you have a problem finding pilots let me know ,when i was jetting these carbs I bought jets by the six pack from sudco ill hook you up for shipping
  20. air leak or harness problem
  21. I was gonna say start with 150 main,50 pilot and work down
  22. I was gonna say start with 150 main,50 pilot and work down
  23. Sound about rite,try leaning it out to a 25 pilot or check your packing in your exhaust
  24. Something aint rite im at sea level 4mil cub 20cc domes 180lbs of comp
  25. Fast clutch all the way,it will last in that application like no other
