350banshee
    PERTH WA
    FMF SST, PORTED JUGS, RAD VALVES, K&N NO LID, PWR RAD, G-FORCE AXLE,
350banshee's Achievements
  1. well i would check but im working away atm so thats all the info i can get right now. i got the carb from here http://www.ebay.com.au/itm/NIB-Banshee-38mm-2-into-1-CV-Carb-Kit-K-N-Keihin-/350354044009?pt=Motors_ATV_Parts_Accessories&hash=item5192ba7469 just added a bigger main jet and moved the needle
  2. hey guys i just finished rebuilding my bike and when its idling for a minute and then i go to push the throtle it stalls ? but when i flick the throttle a few time real quick it will pick up again? mods are fmf sst, single 39mm carb, rad valves, cool head with 20cc domes, mild port , vito pistions 60 tho, ajustable timing plate on +3, and im at see level, 225 main jet needle on top clip and not sure about pilot jet . any help would be great , top end power is awesome just bottom and mid is crap
  3. because ive got the single carb and love it and dont really want to start pushing 2 carbs again. any way i could just go bigger on the carb?
  4. hey guys just want to know if a 38mm single carb would be able to run a 421 cheetah +4 stroker?
  5. hey guys need to know what size jets i need for a 38mm single carb? i have standard stroke ported jugs,fmf sst,rad valves,k&n straight off carb, im at sea level. thank a few sugestions would be great cheers
  6. HEY GUYS I HAVE JUST ORDERED ONE OF THESE KITS SO ILL BE SURE TO LET YOUS KNOW HOW IT GO'S. AT THE MOMENT IN RUNNING STOCK BARRELS WITH A PORT,RAD VALVES,FMF SST, STOCK CARBS WITH K&N NO LID. IM HOPING THESE GO OK BUT ILL BE KEEPING MY OLD BARRELS JUST INCASE.
  7. just got the single carb so stuck with it for a while. so the shearer in frame pipes are no good for me? and do you know any good places in perth to get a port job? cheers
  8. or will i be better off running fmf fatty or sst? or something like that?
  9. hi guys i have a 392 big bore with a single 38mm carb and rad vavles. just want know if in frame shearer pipes would be any good for me? any help would be great
  10. hey guys just want to know what you guys think about getting a 392 big bore ported? or leave it as it is? cheers
  11. check the balance pipe is still between the carbs or its not suckin air in around the reeds or boots?
  12. hey guys im about to buy a single carb setup but dont know what one to get 35mm or 38mm need help? ive got 392 big bore,rad valves and dmc 916 pipes. any help would be great thanks
  13. hey guys just want know if the single carbs are any good going to buy one? any info would be great thanks
  14. hey guys i just got a 421 big bore and put 34mm carbs and running 150 main but it has no bottom end??? runnig fmf fatty k&n strait off carbs. i have to keep clutching it to get it into band then it flys. any help would be great thanks
  15. yeah it sounds like its the left side at idle cause when i rev it and let it come back down to idle the left side carb really sounds like its sucking air big time. ive hade some problems with gaer oil getting in too but ive pulled it apart 4 times now cause thats what i thought it was all along.changed all seals but still the same. tried 320 mains go's good but still does same thing, its good when i get it past the idle stage.
