jlsparky7
Everything posted by jlsparky7
  1. Heres the vids ill be shooting next weekend. Feel free to offer any advice that you think would be helpful to have included in the how to vids. TORS eliminator kit. Case saver install. Swingarm Bearings install. Pilot jet install Main jet install. Any tips or tricks are appreciated Dont even think about bashing me and saying I dont know what im doing. I do but helpful tips are always nice. Thanks!
  2. Couple how to vids in the link in my signature.
  3. Sounds like a lean pilot jet..... Im having the same prob, different setup. New jets on the way.
  4. I agree ^
  5. Alright man. Post back if you need more help. Ill do my best.
  6. Kentucky is going to be a higher elevation than ohio so the air will be thinner and therefor you will be running rich. Downsize the main and get a different pilot in there. Where are you getting the bogging? Down low?
  7. Carb cleaning vid. I show the choke tube in it. Sounds like you need to figure out some better specs on the quad then ask questions, no im not trying to be a dick.
  8. Agreed, tors eliminator kit. 65 bucks I think from fast racing.
  9. Carbs and air filter clean? Heres a vid on carb cleaning/float setting. How do the plugs look? Stock pilots with those mods seem off do you have them turned all the way in?
  10. Gotcha! Thanks!
  11. Anyway to order online from fast racing or do you have to call?
  12. Same setup in the winter 20-40 degrees. What main should I run?
  13. This is the setup im thinking will be perfect. Thanks for the reply. Definitely need the 27.5's as the air screw is all the way in. The 270's seem to give it a huge jump in power so may be a little lean. Ill pick up some 280's as well Thank you!
  14. Stock pilots should be ok?
  15. Thank you for trying to help but there setups are not even close to mine. Different air filters, no lid on the box or running K&N pods, and no .030 over bore.
  16. Not knowing how to jet a carb and not knowing which jet to start with are completely different. I checked for a simUlar post and everyone is running fmf's toomeys dmc's and everything else. No luck with Pro circuits so I figured id just ask. Bash me some more for trying to help.
  17. Anyone? Please? Im shooting a how to vid on the install today and need to know. Thanks!
  18. Sorry, stock.
  19. Pro circuit platinums, shorty silencers. Bored .030 over. K&N with the lid modded. 1000ft. Jetting start?
  20. By ports they mean intake and exhaust ports and no you do not have to get them rechambered. You just have to get a bore and hone done on your cylinders. Itll probably need a minimum of 0.0020-0.0030 taken off. Heres a vid to give you a hand if u need it.
  21. Adding a trans fluid change vid right now.
  22. Alright man. Thanks! Good info.
