03 shee trinity stage 4 2-1 carb kit with 36mm kehin carb uni pod no airbox, dmc aliens, +4 timing, vforce reeds, cool head 20cc domes, running 93 pump gas, 500ft elevation, 60-80 degree weather, i need pilot and main sizes. thanks guys
i have fmf ssts v force reeds trinity stage iv 2 into one intake and a 36mm carb +4 timing elevation is 600 ft and weather is 60-90 f. im running 52 pilot jet and 180 main its off a bit need help for what size it should be. thanks
i garrentee the problem is your carb bowls are on the wrong side. the choke leaver side carb should have a brass pin in it on the back and a little jet on the inside. switch them and she shold run just fine and start in 1-3 kicks like mine does
i brought my 03 banshee in cause it would barley run i put 2 plugs in it cause it seemed like it was running on one plug then i took it apart found out i had a broken reed. fixed that and then put it back together and no spark. all swithes asre on and it was working good when i shut it off. what the hell?
03 shee Ssts vf3 +4 timing cool head 20cc domes stock carbs 300 main 30 pilot middle clip stock needle 500 ft elevation. Notice alot of black oil coming out end of silencers and an the front and I know my seals are all good
it bogs alot before powerband like I no power I have to slip clutch alot what's goin on??? Helpp has alot of top end
what jets should i be running? i have fmf ssts v force reeds cool head 20 cc domes 150 psi comp 400 elevation +4 timing. running 290 mains and 30 pilots seems rich but when i go down to a 280 it is lean. spark plug is black. And it spits oil out the silencers and where the pipe meets the cylinder. dont tell me its my exhaust seals there brand new so are the silencers. and when i get on it and go through the gears it looses fuel and cuts out. idk what to do.
Do i have to jet leaner or richer or just leave it the same if i go from 93 octane to 104 i have sst pipes vf3 reeds +4 timing cool head 20cc domes 150 psi comp 290 mains 27.5 pilot elevation 490 ft i want to drag and get top performance so should i switch orr what
i have 03 banshee fmf sst vf3 +4 timing cool head 22cc domes elevation is around sea level and air temp 70-90 degrees it bogs alot on low end with 0-1/4 throttlee.. i think my mains are good. but too big of pilots. mains are 290 and pilots are 30. i noticed i have 2 strok oil coming out up front and a little out the back. plugs are not white at all there mostly black on the part thats supposed to be white. also with the air box off i rev it to 1/4 throttle and i noticed a mist of gas comes out the back of carbs. but 1/2 to full revving it none comes out. can someone help?? thanks
