Bansh-eman
Everything posted by Bansh-eman
  1. http://www.bansheehq.com/forums/index.php?showtopic=92303
  2. i have never installed a 2 stroke that had more then one ring. thats on gokarts, dirtbikes, and quads. its possible but i havent seen anything with it you sure you installed prolites? banshee prolites dont have 2 rings. and the blasters are the same
  3. a 2 stroke piston normally has only have 1 ring
  4. buy a CR250 kill switch and get rid of the big eye sore. kill two birds with one stone. then you can move the lights to a hidden location
  5. it should be fine
  6. your backwards... its not holding pressure and letting it out. the cap is not going to fix the problem. the problem is in either the dome/head or the jugs.
  7. on top of the swinger to keep the slider from turning
  8. heat.. use a small torch to heat them up and it should come out
  9. all the sliders you have to remove the swinger, and it just pushes over the end where the dust cap goes. there is one that i have seen that has a screw so you dont have to remove the swinger but i cant remember the brand off the top of my head
  10. when my bike was near stock i had put bigger pilots in the carbs and it woudlnt start. put the smaller ones back in and it fired right up. whats jets are you running?
  11. its also very nice for those bikes that are hard to find neutral. you just click down and walla
  12. that is correct, a cooling system not holding pressure will NOT cause your o rings to keep popping out. its something with your domes, head, or your jugs.
  13. what oil do you normally use? i have never seen a premix that isnt some sort of coor. so it should be a dead give away if its mixed
  14. it's the exact same bulb
  15. yea that dude that i sold it to should go to jail for rape!
  16. how much drugs do you sell to support all your toys?
  17. sounds like something is warped or un-even
  18. use a socket extension through the rods to hold them from spinning.
  19. i was the one that found those screens and posted hthem. only thing is they burn out very fast! mine lasted one trip and the screens where gone. make sure your keeping tabs on the screens to see they are still there
  20. One Word SEARCH!!!!
  21. HAHAHAHAH
  22. boo it got removed what was it?
  23. when you say auxillery ports are you reffering to the small ports drilled at an angle at the bottom corners of the intake like in this pict? btw thats a blaster motor so dont worry about it having them on top as well
