Bansh-eman
Everything posted by Bansh-eman
  1. Actually thats from the song Off Broadway. but it is the same album
  2. post a pict of where you think it is coming from...
  3. yes loosen it to have 1/2 in to 1in play while your sitting on the bike.
  4. it can cause the chain and sprokets to wear faster. if its SUPER tight it can cause issues with other parts but it has to be really bound up to do that in most cases
  5. no he is full of crap. He just isnt doing something right. I have my TORS long gone and mine plugged right up. There are extra wires that are not used and he is probly assuming you need to hook them up.
  6. look up Havok Racing, his screen name onhere is blewbyu or something like that. He makes great products.
  7. its not long enough to put it on your bars. i have mine mounted under my seat at the rear.
  8. they are good cdi's, they really shine if you have access to a dyno to reprogram it
  9. I suggest that you do alot of reading old posts on here before you dive into buying anything and learn abot what is what. Thn when you think you know what you want start asking questions and make sure ou got all your bases covered.
  10. Hot Rods 2751 Parkside Circle Urbandale, IA 50322, USA Ph: 515-402-8000
  11. are you sure its 105? i remember reading somewhere that it is lower then regular pump gas. I couldnt tell you for sure because i havent looked into it. Just remember someone saying that a while back
  12. it acts like another seal, jeff should be able to get it for you. If you can get ahold of hotrods you might be able to order a replacement
  13. i have had pretty good luck with dot 4 not eating my PC. I am usually good about getting some simple green or somethig to wash it off but not always.
  14. Your fucking HIGH!
  15. Yea your telling me, my wife is pretty mad that I'm selling it at that. I have lots more into it. I don't plan on bouncing out of here, hell maybe i can win the raffle bike i got 10 tickets heheh
  16. i dont see why it wouldnt work, most other motor iv ever worked on beside quads and dirt bikes use bolts instead of studs.
  17. it is showing double becasue the banshee ignition fires both plugs at the same time. it does not fire back and forth. so for one cylinder it will fire at TDC and BDC, this is in turn giving you double the rpm for that cylinder
  18. nice set man! i used to have a premier set back in the day that i got raped on to get rid of. spent around 3 or 4 grand on hardwear and everything and sold it for next to nothing
  19. Yup he's 6 months
  20. I concur, I'm kind of upset to be getting rid of it, I just have alot more to be dealing with right now in my life.
  21. Ok guys, the time has come that I have more on my plate that I need to be focusing on beside this bike. I'm sure most of you know alot about the build but for those who don't here is a list of parts. My wife and I just got a new car on a total impulsive buy. I need to get my money back into my account for other investments. Asking 9k. Located in San Diego. Will ship at your expense. Comes with clean title. Bike has only had 3 heat cycles. Motor is Literally Brand New. 2000 Banshee 421 Cub Polished Cylinders Weisco 68mm Pistons 1-5 Duneable Override Neutral Down with DD Lockup Hinson 8 Plate Clutch (Billet Basket, Inner Hub, Pressure Plate) Shearer Inframes Dyna Tek CDI Nology Coil with Hotwires NOSS Coolhead 20cc domes 185 PSI Sea Level Hotrods 4mil cranks Trued and Welded (NOT Garbage Factory weld) VF3 Reeds White Knuckle Racing Billet Intake with Built in Crossover 35mm PWK Pods with Outerwear Dual Flow Pingle Billet Gas Cap ASV Brake and Clutch Levers Cascade Stator Cover Cascade Water Pump Cover Cascade Pipe Clamps Cascade Front Pipe Hangers Yakkey Shift Drum with Bearing Adjustable Billet Rear Exhaust Hangers Trail Tech Lights Ricky Stator 200w Stator Upps Chain guide sliders and rollers DD Reinforced Clutch Cover with Blue Lexan Cover Billet Water Impeller +2+1 Wicked A Arms +2 Anti Vibe Stem +6 Quicksand Round House Swinger RPM Extended Axle LoneStar Lock Nut Extended Thumb Throttle SS Front and Rear Brake Lines Brand New EK Non O-Ring Chain New Front and Rear Sprockets 14/41 gearing Front Marvin Shaw Comps Rear Marvin Shaw Hillshooter New Seat Cover 10 Paddle Haulers Custom Paint Job Done by JK Customs All Nuts, Bolts, and Washers have been replaced by either polished or chromed Allen heads this include carbs and carb boot bolts. The only things not replaced are hose clamps, Lower Motor Mount Bolt, Upper A Arm Bolts (which are polished and cer zinced), Pegs Bolts (which are polished and cer zinced). New Powder coated Frame, Spindles, Wheel and Axle Hubs, Handle Bars, Case Halfs, and Linkage Candy Blue TONS OF Chrome
  22. looking for a nice fox body, a 97-98 or a 03. Those are the body styles i like
  23. it might be tranny oil from a crank seal leak. When coolant mixes with oil it normally turns milky
