hi there,
to check if there is fuel in the bowls, you turn your petcock on. then you undo the screws on the bottom of the bowls and visually see if fuel comes out of the drain hoses next to the screws. another trick is to take off the air filters and cover the carb opening with your hand and kick it over. you should see fuel rise out of the main nozzle.
