ohiobanshee
Everything posted by ohiobanshee
  1. Welcome. There is enough people on here that will help you fix any problem you might have with your shee, all you have to do is ask. :beer:
  2. The stock and 40 your refering to is the diamenter of the axel not the carrier. Most of the aluminum drag axels are 40mm,they take a special carrier.
  3. I have one,let me find it.
  4. Need 1 or both sides silencer and stinger, if only 1 than I need the left side. eric
  5. I have some stock ones you can have just pay shipping.
  6. Make sure that the choke tube is conected between both carbs.
  7. Make sure the shiftter is adjusted right inside, centered by the ecentric adjuster,also make sure the piece that grabs the shiftstar pegs is not worn,should be a tiny hook on each end that grabs the pegs.
  8. What kind of tires were you using?
  9. I have a red and black 96.
  10. ohiobanshee
    tires
    Ok tried this in the mod section,hopefully i'll get more ideas here.Need tires for concrete like hard packed dirt drags. My pro wedges spun bad,so did all the bikes on nobby tires. Would turf tamers or tt style tires hook better? eric
  11. I have a 89 shee it was eating plugs too,changed everything wiring,stator,cdi,coil but the flywheel.Changed flywheel,problem solved. Further tuning on the carb,which is a 34pj required a needle change from a ceg to a cel. The cel is leaner on the bottom. eric
  12. Any carb will work as long as it fits the intake boot. I have a older trinity kit with a 34pj that I love.
  13. Raced last night on hardpacked dirt,spun the shit out of my pro wedges.What is a good tire for hardpack? I was thinking about turf tamers or tt style tires. eric
  14. Also check and make sure you don't have a vacume leak. Spray carb cleaner around your intakes and reeds if it revs up you have a air leak.
  15. Thanksfor the help. How do you determine the length of the bar? Bigboy will that setup work on a suspended bike? eric
  16. Wanting to make a wheele bar for dirt drags. Where is the best place to mount it? To the frame or swingarm? If anyone has pics please post them. Have less than a week to get this done. eric
  17. He has had my tranny for over a month now. When I shipped it too him he said two weeks. When I called last week I was told I was third in line. Wish he would hurry up,but I am not going to bitch yet.
  18. WSM makes a 68mm piston with the banshee dome and stock pin heigth. Check TDR in florida.
  19. If the rear grab bar is still available pm me a price with shipping to 45101. eric
  20. Heres the pics.
  21. Do a leak down test with the radiator cap off. If you get air bubbles in your coolant you have a blown head gasket.
  22. I'll back you,but first you have to help me jet my 12ports. :biggrin:
  23. You have a pm. :beer:
  24. Found the problem, the coilwires were rusty and coroded in the coil and plugboots. :thumbsup: thanks eric
