ohiobanshee
Everything posted by ohiobanshee
  1. How much is shipping to 45101?
  2. Would you take $400 shipped?
  3. Can you take a pic of the cut on top?I am interested in them. Shipping to 45101.
  4. Were have the fronts been trimed?
  5. What he is asking is are they banshee style pistons or blaster style.The tops of the pistons are curved different.Blaster pistons are flatter than banshee pistons.If you need more help I can post a pic of the two types so you can see te difference.
  6. I don't think so,she still has cloths on. :yelrotflmao:
  7. I painted my t5's red with high temp brake caliper paint with ceramic in it.Did a couple of heat cycles to cure the paint,it's held up good so far.
  8. Look at it this way,you can tell people that the motor is so powerful that it destroys trannys every time you you get on it.
  9. Let me find my old one,I took it off and put it up somewhere when I got my pingle.I'll pm you tomorrow if I find it. eric
  10. I saw the one's you did for Matt,that is what got me considering blue,I was set on orange.What ever I decide I am going to do the frame in marblizer and have you do the plastics.Could you paint my helment to match?
  11. I have a buddy that has a green bike,gotta be differe :thumbsup: nt.
  12. Building a drag shee,stuck between two colors,orange or blue.most everything else will be chromed or polished. eric
  13. here's anouther http://www.bansheehq.com/forums/index.php?showtopic=90892
  14. Looking to buy a new auto darkening helmet.What do you use,pros and cons. eric
  15. The smallest I would go in front would be a 13. I had a 12 on one of my bikes and I hated it. As soon as you hit the powerband it would rip the front tires off the ground,grass,gravel didn't matter it wouldn't spin,just wheelie.Hard to steer when your front wheels are off the ground. ::
  16. ohiobanshee
    warrior
    A friend has two for sale in ohio.
  17. Look under Minkia38 in the foresale section,I think he has some. eric
  18. I have a stock one -2,you have to run a strut.It was cut infront of the dogbone mount.I was using it for dirt drags.
  19. The instructions are used to get you close,you will have to fine tune it yourself.Start with your air screws 1 1/2 out,go a 1/2 turn at a time till the bog is gone. If you go past 2 1/2 out you need bigger pilots.If the bog is past 1/4 throttle you will need to move your needle clip position.Try pulling the choke when you try to take off,if it helps you are to lean on your pilot or you can try moving your needel clip down one notch.
  20. Try turning your air screws out more.If you go past 2 1/2 turns out you need bigger pilots.Stock pilots are 25's.Did you set the needles 4th from top or bottom?
  21. Bad bearing,crank not true or the seal surface nicked up.
  22. Look in bigred350x's sig.
  23. I try to keep 1 or 2 running at all times. :yelrotflmao: most look like this.
  24. Give me a couple days to take inventory,I have 11 quads and god only knows how much stuff to go on them. My sig would take a couple pages.
