ohiobanshee
Everything posted by ohiobanshee
  1. Good one travis,thats funny as hell. :thumbsup:
  2. This should be mj's avatar.
  3. Spark?choke tube hooked up?
  4. Pm me your address,you can have this one.
  5. I have one.
  6. Easiest way I have found is to open one bleeder and squeze and hold the brake lever,tighten bleeder than release brakes,it pushes the air out instead of compressing it.
  7. Fmf fatties with billet clamps $200 +shipping
  8. If you rev the bike up does it take a while to return yo idle? If it does,check for a air leak. Spray carb cleaner around the carbs and reeds with the bike running and see if the motor idels up.
  9. Your sick :laugh:
  10. Bigboys nitrous solonoid stuck and gave his reeds a big boost back into the carbs.
  11. I had 35's on it,34's will work also.Yes shipped $85 total. Where in ky are you at?
  12. http://cgi.ebay.com/2003-yamaha-banshee_W0...1QQcmdZViewItem here you go dave.
  13. rdz oof,too loud
  14. I have both $40 a set.
  15. I have a billet intake $85 shipped
  16. If he doesn't answer the phone,he might be busy doing his second job as a nut carrier. :yelrotflmao:
  17. Is the bearing comming in contact with the weld when you tighter the nut?Pull the crank back out and tighten the nut,look to see if the bearing touches the weld.Or the weld hitting the cases putting the bearing in a bind.
  18. Why did you tear the motor down to begin with?
  19. What exactly does it do to the bearing?Can't understand how tightning two gears and a spacer against the inner bearing race could lock the crank.
  20. Check out www.dirtcountrymx.com it's in blanchester a little town north of cincy.
  21. Ben there done that,3 years later I have a 2year old and one due at the end of february. As for the check,DM cyls for the drag bike.
  22. You have a pm.
  23. Does she go with it? :biggrin:
  24. The older sprockets had 4bolts holding them to the hub,newer style uses 6bolts.
  25. First under performance :thumbsup: You should start carrying this stuff. :laugh:
