ohiobanshee
Everything posted by ohiobanshee
  1. SOLD SOLD SOLD Thank you Ray (Minka38)
  2. parting out only if i can sell complete engine 1500
  3. Not sure of the bore size,I know its not on the last bore. The porting is by Passion Racing,its his Hot MX 12 port port job.it pulls really hard mid thru top,but it still has good low end for trail riding with the air striker carbs.
  4. possible part out if anyone interested
  5. Orange powder coated frame,gripper seat cover,yfz 450 a arms,shocks and dual piston front calipers,billet aluminum tie rods,aluminum flamed bar clamp,e brake block off, water pump cover,aluminum front bumper,rear grab bar,rear skid plate and nerf bars,DMC pipes,cascade v bar handle bars,full bore front plastics,stock rear,+2 axel with anti fade lock nut,aftermarket rear brake rotor,new brake pads front and rear,complete stainless steel bolt kit on bike,cdi relocated. Engine 70 horsepower,4 mill stroker weisco trued and welded crank,Passion Racing ported stock cylinders,cool head with pump gas domes,boss billet intake,keihn 35mm air striker carbs,billet clutch basket,modded shift star,WCR dunable 1 thru 4 tranny with manual 5th and 6th gear,15-41 gearing,double wide foot pegs with kickups,pingle dual feed petcock,nology coil and wires,billet adjustable timing plate,billet water pump impeler,V Force reeds. 3,500 OBO for 6,000 i will sell bike plus every banshee part i have,nitrous kit,pro wedge tires mounted,+2 over stock style swing are,+12 over round housing swing arm,like new kehin 35mm PWKs,3 frames 1 lightned,extra sets of plastics,gas tanks,carbs,engine cases,cranks,cylinders too much to list. 937 515 1415 Eric
  6. 87- 2GU-000101-030100 Your numbers are between those two sets,that means it's a 1987.
  7. Look at his feedback,he's getting rich off these pieces of shit.
  8. I have one,but it's on it's way to Jeff for a little grinding.
  9. Only parts I need are 10mil cubs.
  10. I have a unported,unplated 10mil DM forsale $600 shipped.
  11. Black and orange.
  12. Doesn't look like he's that well trained,or was he trying to bring the banshee to you. :yelrotflmao:
  13. http://www.usatoday.com/sports/boxing/2009...th_N.htm?csp=34
  14. Do you have the brake light switches?
  15. I like the Rad Valves on unported banshees with stock carbs.
  16. I used a port a power to jack mine out. I unbolted the stem from the hoop than jacked up the hoop till it touched the stem than I went 1/4 inch more.
  17. With those mods,should be more like 140. :yelrotflmao:
  18. Try the FAST easy pull carb springs,they made my 35,s easier than the stock carbs.
  19. Damn I should have kept my old 200 BigRed. :yelrotflmao:
