375hp banshees
    209
Everything posted by 375hp banshees
  1. Yes, piston pushes on 1 pad, then draws caliper over ( on slide pins) so other pad pinches other side. Ya know just like cars &... trucks.
  2. Slide pins are frozen or caliper piston is froze?
  3. Call Jose 407-952-7207@ atv mainac service & performance & see if he will do what you need, if not he'll know who will.
  4. Check compression, spark & did you do a leak down? Lights are on a separate winding than the ignition
  5. How do you know its not plug or spark? Pipe full of gas rats nest in pipe Float adjustment Bad float needle and/ or seat ...
  6. I dont think so . I was thinking you put wrong year cdi on not stator ...nvm
  7. TORS kills ign. Completely, p. Brake limits the rpms ( very low) but idles fine. Fyi
  8. What does it do above an idle? P- brake rev limiter?
  9. I meant on key plug. Should be B/W, B/R, R, Br Those are tied together so it'll start w/o key sw then. connect as said above.
  10. What year ? You sure the black doesnt have a red stripe <2001 Black on harness goes to B/W on main switch And R/B on harness to B/R on switch B/Y should be TORS & not hooked to black ( but i assume thats all disconnected any ways?)
  11. Float level ? if its flooding down low ( not using the flooded fuel to lower the level) it'll be way under power down low, then when it clears out ( and uses enough fuel to not overflow anymore) the power will seem more cause it coming off of no power down low? Tip up on end too, to see if there's fuel in the pipes?
  12. Youre off the throttle & eng. Braking? Exh leak?
  13. If it was coolant, then yes. you also have 2 vent hoses for trans, that "T" together & run up also, so
  14. Or sell it for $100 buy $25 jds bracket & pocket $75
  15. Think jds sells a bracket
  16. @SemperChaos He just wanted to show off he knows alot about... hard stuff
  17. Took 1 fer da team, you saw shrink me, and it was....irresistible
  18. 3rd rate site..  at best
  19. Put og jets back in & hopefully the og problem was fixed, with the 1st cleaning. Sent from my SM-A505U using Tapatalk
  20. I think its a guide not really a jet Sent from my SM-A505U using Tapatalk
