375hp banshees
    209
Everything posted by 375hp banshees
  1. FFS it's a sideways pic... Those are chins
  2. Some don't, it's just a bearing keeper " plate, cover" 4L0-17471-00-00, screws w/ washer = 98517-06012-00... if you need
  3. Or justa...four chin teller?
  4. Psychic?
  5. Windows are @ wot usually you need to get longer cap screw/ cable inserts, but That'll make it worse. I dont think it'll hurt to go above windows, just check sync at window when they line up.
  6. Do it be ok to drink beer after getting home from da gym At night, Of course...im not smephen
  7. Pilots kinda small, could bump that up& try. But if it was fine before...? Sent from my SM-A505U using Tapatalk
  8. Why did you clean them? Put choke tube back on? slides in correct carb? If it pops off with spray, your not getting fuel...open drain & make sure bowls are full, if so re-clean carbs
  9. ... and report back so others will know what it was. This site is here for more stuff than... biden BuLl sHiT tHReaDs
  10. Sign dis mudder fuq'r up to be a sponsor!! !
  11. *Herr jugs I wouldnt get domes from him @ride.race.live
  12. But since you already bought it, hit up one of the site sponsors they can hook u up ... notice trinity isn't a sponsor
  13. SKEETER iz dat u?
  14. 👍
  15. @97Screamer
  16. Measure port openings & compare port timing ...if others arent assembled
  17. F.A.S.T.
  18. Cant hurt...Easier than splitting the cases & welding Sent from my SM-A505U using Tapatalk
  19. Might want to take a measurement in case you need to drill it out and redo it. so you don't drill too deep. And put a center dimple in it, while it's still soft.
  20. I would clean it real good. use a tiny amount of silicone or something similar to seal the very End of the hole, to stop it from leaking anymore, let it dry After it's dried good. clean it again, scar up the hole (more horizontally, than vertically) so your epoxy of choice will stick, and use devcon ,JB Weld... if it doesnt work you can re do it & fill it up untill that whole cavity is full if needed Sent from my SM-A505U using Tapatalk
  21. Yeah well his can see ...so now what? Sent from my SM-A505U using Tapatalk
  22. Did you pull it apart to fix, or that is a random pic. ? Sent from my SM-A505U using Tapatalk
