bansheeseat$$
Everything posted by bansheeseat$$
  1. "Quote I think by Pressure test he ment a leak down test".Yes thats what I meant,my bad.On the leak down test your engine needs to hold 6psi for 6 minutes.
  2. Do a search on here.There should be thread somewhere on how to do it.If not PM me Your PH# and I will explain how to do it.
  3. No not a compression test.It's a presure test of the internal engine assy itself.
  4. The big clutch nut is 32mm.As for the T.O.R.S removal if your wanting to go to bigger carbs sooner then later get diffrent carbs if not get the eliminator kit.And for the single carb I like them but alot of peaple don't.
  5. Do a engine pressure test.That will tell you if you have gaskets and/or seals leaking
  6. Go with the v-force reeds,bigger carbs and exhaust and it should hall a$$.
  7. It ran the exact mph just a gear higher.So I installed a lock up clutch setup but was unable to go out on saturday(5-27) to cold So I'm going out This weekend(6-3and4)And I'll see what happens.
  8. On the fenders I just shimed the bracket at the frame mount and called it good.As for the air box its got to go.
  9. My freind has one on his stroker banshee and love it.It looks really good for the price.He only rides it in the sand though so I'm not sure if it would be as durable as a lonestar axle.
  10. Call Tim at cascade on tuesday.503-663-2887.
  11. I'm selling my 32mm mikuni flat slides and steel braided thumb throttle cable on ebay.Will end early for right price. http://motors.search.ebay.com/_W0QQsassZbansheeseatQ24Q24
  12. Don't do it,you'll be so mad at yourself within a week!!!
  13. Run it wide open in fifth gear and then pull in the clutch and shut it off and then stop.Pull the plugs and go from there.
  14. I got a pair of 32mm mukini flat slides and steal braided thumb throttle cable,Also have main and pilot jets.
  15. 20 means height 11 means wide and 9 means rim size.
  16. Yes it is and the rear wheels have more of a offset verses the banshee wheels. when the valve stems are facing out
  17. Go with v force reeds.
  18. You need to make sure that your test equipment is not leaking.with that much of a loss you will not be able to accuratly test your seals and gaskets.When I did mine I lost 1/2 pound in six min witch is ok.My 2 cents.
  19. I know how you feel.Last weekend My left silencer mount broke and the throttle cable holder broke on my o6 shee and my kicker shaft broke on my 05 shee all the same day and three hours apart.
  20. I'm running 45 pilots and 145 mains at 4000 feet and I'm still alittle rich.I would try 140 mains with 45 pilots and middle clip on your needle.
  21. Check your float levels.They maybe set to low.
  22. I use spyder grips and love them,But it depends on how big your hands are.The spyder grips are designed for biger hands.
