Rare Scottish Tree Badger
Everything posted by Rare Scottish Tree Badger
  1. Sounds like a piston's busted up and pieces of it have jammed under the crank. Rare.
  2. Yip. ... Wouldn't it be funny if he came to work on Monday and had no high scores left. . I think you'll be ok, Brad. Rare.
  3. You just lost a tittle, Brad. ... Rare.
  4. That should give you more incentive! Rare.
  5. That makes me think your mains need to be bigger. J.J. ... Partially blocked, maybe. But 'blocked' will lead to a 'no run' situation. rare.
  6. Happy Birthday Neil. ... Big THREE OOOOO! Dave.
  7. I want your space invaders high score! Rare.
  8. Nice find, RNBRAD. ... That made for some interesting reading. Rare.
  9. That's where I'm at too! ... Same numbers on an MX port job. (660 ft) Sure makes for a great motor. Rare.
  10. Sad day. ... Can't you just give him the garage wall? Rare.
  11. Do we all believe in them until the punch line? Rare.
  12. Good info. More than what I knew. Rare.
  13. Yip. ... Now you can attempt to take some of the games tittles off RNBRAD. First thing I'd do with that is 'own' space invaders! Rare.
  14. DynaFS for me. ... Stock curve: "improved microprocessor control and significantly higher spark energy." Rare.
  15. Lightened flywheel will pick the revs up quicker. Rare.
  16. Any pics? ... Glad you're ok. Rare.
  17. That's one DUMB blonde! Rare.
  18. I got a full refund (less shipping) and got to keep the shock. So I guess I will try to make one good one out of the two. ... And I'll check out having one of them sent out for a rebuild. Anyone know of anywhere in the UK that does shock rebuilding? Rare.
  19. If your off-idle to 1/4 throttle and above can take a richer mixture, then try it. ... Yamaha std. pilots (#25) IMO are good for a fair amount of tuning. ... I'd be adjusting my idle at the screws if it's only a tickover problem. Rare.
  20. Assuming you're 'piped' with those 290 mains, I guess that the increased compression has left your cylinders short of mixture at idle. ... Use adjusters to icrease idle speed (raise slide). Rare.
  21. Pull the plugs. ... Do they tell you anything? Rare.
  22. Agreed. ... If you want the benefits of a WRX in a Dodge Viper shell, then go for it. (Based on the {guessed} opinion that there must be something that a WRX does better than a Viper). If my Banshee (modded the way I got it plus more) was 'DeTuned' I would go faster in MX! But I put that down to inexperience. ... I'm learning the hard way! Rare.
