ojcool Posted February 23, 2007 Report Posted February 23, 2007 (edited) I'm strapping the banshee down this weeked. Everyone guess what I will make. .080 over with Wiseco's 19cc domes +4 timing Unifilter in stock box no lid LRD pipes (adjustable set for hi rev) Trail Port (no port timing changes) SRP cages with Boyseen reeds Stock carbs Got 330's in it with 30 pilots (Ill also post the a/f ratios vs RPM) If its rich I'll lean on it to around 12:1 A/F ratio What gear do you guys usually make your pulls in? If I make 47hp I'll be happy. Edited February 23, 2007 by ojcool
Hollister_Hitman Posted February 23, 2007 Report Posted February 23, 2007 I'm gonna say 13hp over stock.
ojcool Posted February 23, 2007 Author Report Posted February 23, 2007 82hp, 64 ft lbs. Whoa dude, did you see a boost bottle in my list of mods?
camatv Posted February 23, 2007 Report Posted February 23, 2007 dont forget to play withthe pipes adjustment also. move them about 10mm at a time and do different graphs. with not internal port changes the bikes not going to do much decent port timing changes could get you intot he 55's to 60+ i bet you are pretty close with the 45-48ish..
8buck Posted February 23, 2007 Report Posted February 23, 2007 I suck at guessing but you'll pull in 5th gear. It's closest to 1 to 1.
06BaNsHeE Posted February 23, 2007 Report Posted February 23, 2007 321632135731324654hp Damit didnt you read he doesnt have a boost bottle lol j/p
trueraiderfan Posted February 23, 2007 Report Posted February 23, 2007 50 hp if its tuned right on the money.
sredish Posted February 23, 2007 Report Posted February 23, 2007 (edited) You should bust 47 pretty easy, I'd guess mid to low 50's. Just remember you can't compare one person's dyno to another. While they'll be close, Dynojets typically see an 8 to 10 % difference in readings which be around a 4 to 6 hp difference; so say you have a 54 hp machine, you could hit 50 on one and 56 on another. Edited February 23, 2007 by sredish
FireHead Posted February 23, 2007 Report Posted February 23, 2007 I'm strapping the banshee down this weeked. Everyone guess what I will make. .080 over with Wiseco's 19cc domes +4 timing Unifilter in stock box no lid LRD pipes (adjustable set for hi rev) Trail Port (no port timing changes) SRP cages with Boyseen reeds Stock carbs Got 330's in it with 30 pilots (Ill also post the a/f ratios vs RPM) If its rich I'll lean on it to around 12:1 A/F ratio What gear do you guys usually make your pulls in? If I make 47hp I'll be happy. What kind of dyno are you going to be running it on (chassis/motor; brand, absorber type)? If it is a Dynojet inertia bake dyno then I guess that your will make any wgere from -12hp - Eleventy Billion hp.
Washburn Posted February 23, 2007 Report Posted February 23, 2007 321632135731324654hp pfffft my sisters pink huffy makes more than that
