927 leaves some buildup in my pipes etc, but damn it smells good.
Switched to MC1/HR1 but currently using Amsoil Dominator. I like the synthetics better, they mix easier, protect well, and don't seperate like 927. But 927 is the way to go if your running Alchy
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
Use Klotz R-50, burns cleaner than beanoil, and supertechniplate, plus they rate R-50 at 9.5 portection and beanoil at 10 but R-50 burns twice as clean. Go to klotzlube.com and find the oil then click on tech sheet. pretty interesting stuff.
been using Klotz R-50 32:1 for years with no prob. good stuff :thumb: great film strength, burns very clean, mixes easily, and smells great when mixed with racing fuel. :beer:
castor 927 for sure it adds hp!!!! :headbang: an its synthetic
Wrong, 927 is not synthetic is is BEAN oil, and it does not add HP it's just oil after all.
I don't care what their site says, Bean oil is not a true synthetic.
In fact, many synthetics specificaly say not to mix with castor oil..
Edited by Justintoxicated
You guys can goof on me all you want but..., I have a pretty mild bike, and I've never run into a problem with 32:1 Yamalube Race Oil. Got a shit load of it for next to nothing from a buddy that used to work at Action here in NJ. Can't complain at all, of course I've only used amsoil besides the Yamalube.
I've run 927 for years and have had ZERO problems. But like was stated earlier. It will seperate. When the temps start getting around 40 degrees. Make sure you shake your gas can. I always turn the fuel off and drain the carbs. IT will leave a gooey mess in them if you don't and the temps turn cold.
Mobil 1 2t, also note that when an oil specifies that it is sythetic it does not imply that it is not crude oil. I know it seems stupid!! Synthetic to most of us means man made or a duplicate of something real. In the oil world synthetic has to do with performance characteristics and not production. So in actuality you can have 2 different oils with labels on both stating 100% synthetic. One may actually be a true synthetic and the other a highly refined grade a crude oil. Both will have relatively the same performance. Now you know the rest of the story!!
I was going to order some diff Klotz formulas but I was wondering will these heavier oils mix easily in the gas tank itself? I am forced to do this from time to time. I use Amsoil Interceptor now and I have done this on many occasions and not had a problem. Will Koltz?
