tithead Posted May 31, 2006 Report Posted May 31, 2006 dont think you have to try and jump..... keep the power on and let the bike glide. Quote
Rustbag Posted July 10, 2006 Report Posted July 10, 2006 Keep the rubber side down! :thumb: Good one. :thumb: Quote
375hp banshees Posted July 13, 2006 Report Posted July 13, 2006 Hey all... I'm more of a woods rider, but would like to get into MX. What are some tips for getting good air and decent landings? Any info is much appreciated.... me to just for fun hay guys what about F shocks everybody's running top of the line ELKA's, can I get away w/ some lower spec (lack of A better word) elka's or just bite the big one . I wanta get A-arms & axil but just hitting small jumps w/ A flat landing hirts these old bones so I/m getting shocks 1st what can I get away with ?? Quote
korndawg Posted July 13, 2006 Report Posted July 13, 2006 hay guys what about F shocks everybody's running top of the line ELKA's, can I get away w/ some lower spec (lack of A better word) elka's or just bite the big one . I wanta get A-arms & axil but just hitting small jumps w/ A flat landing hirts these old bones so I/m getting shocks 1st what can I get away with ?? I'm running the works AT steeler dual rate shocks without rezzies. I do a little bit of jumping every now and then, and they seem to work fine for that. If I were planning on doing alot of jumping, or catching some big air, I might look into some of the higher priced shocks though. The works shocks are alot easier on the wallet though. I ordered mine directly from works for less than $400. Quote
Blue Duece Posted July 13, 2006 Report Posted July 13, 2006 land on the down hill of something, anything it doesnt matter just dont land flat Quote
375hp banshees Posted July 13, 2006 Report Posted July 13, 2006 (edited) land on the down hill of something, anything it doesnt matter just dont land flat the local track i'm starting on w/ very small jumps (some of them are suposed to be doubles but I'm not ready for that yet) so you ether(sp) roll over them or jump slowly & land flat or if to long on the next ramp up OUCH! :baseball_bat: "I'm running the works AT steeler dual rate shocks without rezzies. I do a little bit of jumping every now and then, and they seem to work fine for that. If I were planning on doing alot of jumping, or catching some big air, I might look into some of the higher priced shocks though. The works shocks are alot easier on the wallet though. I ordered mine directly from works for less than $400." what's the purpose / benefit of rezzies Edited July 15, 2006 by 275hp banshee's Quote
atvaddiction Posted December 6, 2006 Report Posted December 6, 2006 i just try to stay loose on the bike and then u can leane wat ever way u want to put hte banshee good luck!!! Quote
bertski077 Posted December 6, 2006 Report Posted December 6, 2006 a very important thing to remember is if your gonna hit a jump u HAVE to commit to the jump you CANNOT back out at the last second good luck im still tryin to learn im racing mx on my shee next season Quote
Washburn Posted December 7, 2006 Report Posted December 7, 2006 Ive been taking it easy on the jumps for a few reasons. 1. I have a bad leg and the stock shock SUUUUUUCK! 2. The Banshee is alot diffrent to jump than my old LT250R. Ive noticed on pretty much every jump I end up picking the front end up a little so I dont land on my front tires or do a nose dive. Ive been getting like 4-5 feet of air and landing flat and its brutal on my leg. Ive found some good downhill landings though so Im gonna try more of them tomorow and friday-sunday. I also push my ass back a bit when I am ready to hit the jump and I land without hitting the seat. It can take some practice. Im new to this too and the best advise I can give you is start small and try to land on a downslope. Im gonna try to get some footage of me climbing the superbowl and suicide hill this weekend too along with some air. Quote
mavbike Posted December 8, 2006 Report Posted December 8, 2006 the local track i'm starting on w/ very small jumps (some of them are suposed to be doubles but I'm not ready for that yet) so you ether(sp) roll over them or jump slowly & land flat or if to long on the next ramp up OUCH! :baseball_bat: Depends on the size of the doubles. If they are small, just hop the first one and run hard at the second. If they are big, roll the first one and use the down slope to help accelerate hard at the second. Quote
band-one Posted December 10, 2006 Report Posted December 10, 2006 Starting smalll is good advice. Once I got completely comfortable with the banshee, I started small jumps and worked them till I had them nailed and worked my way on to bigger ones. It;s all about knowing your machine...and your limits! Quote
4everwantedbanshee Posted December 10, 2006 Report Posted December 10, 2006 Starting smalll is good advice. Once I got completely comfortable with the banshee, I started small jumps and worked them till I had them nailed and worked my way on to bigger ones. It;s all about knowing your machine...and your limits! this is about the best advice ever. its the same way with bmx. thats how i know how to jump. i dont do big sh!t but. i am getting up there Quote
SandShots Posted December 16, 2006 Report Posted December 16, 2006 steady throttle. Don't bleap the throttle of the lip. Keep a constant throttle and the rest should be natural feeling. If you are in trouble just remember rear brake to bring the front end down and get on the gas to bring the back down. if you need to use the rear brakes while in flight, does that mean we gotta grab some clutch so the engine doesnt stall? Quote
dawarriorman Posted December 16, 2006 Report Posted December 16, 2006 if you need to use the rear brakes while in flight, does that mean we gotta grab some clutch so the engine doesnt stall? Yes, you want to grab the clutch to use the back brakes. If your just starting out, its probably easier to just grab the front brakes instead. They won't drop the front end as fast as the rear brakes, but its easier to just reach a finger out and grab them. Make sure you let off before you land though. Quote
