atvaddiction
Everything posted by atvaddiction
  1. Still have stuff availible except the renthal bar pad
  2. Still have this stuff for sale.
  3. This is a pile of part that I have laying around after a Banshee Part out as you can see there are a lot of parts for a Banshee here. All parts are used and in usable condition. Any questions feel free to ask. Thanks. There is a lot of stuff here for a great price. $75 for everything listed below. Header pipes Set of mid section to exhaust with heat shields Extra mid pipe Ignition coil with fit all year banshee's 4 Axle Nuts Steering Stem mount clamp Coolant hose from cases to head 5 air box to carb mounting boots for intake Other misc rubber mounts/covers Swingarm pivot caps Swingarm pivot chain roller metal bushing Clutch lever and perch Front brake lever Clutch springs Kill/Light switch 1 black set of handle bar clamps 1 silver set of handle bar clamps Set of wrist pin needle bearings Oil dipstick TPS Controller Back Brake resivoir cap Little handlebar lever for Misc use. 2 Coolant overflow bottles Rear dogbone suspension linkage for shock/swingarm mounting Clutch Cover insert Water pump cover Renthal Racing Handlebar pad Fly Racing pad cover Steering Stems $35 for both $20 a piece Brand New ITP Sand Star Rear Left Paddle Tire 20x11x8 L
  4. 9 hours still only $49
  5. 1 day left on ebay still only $50
  6. Sorry I do not have any.
  7. This is on ebay right now for $49.99 with only like 3 days left.
  8. I sent you a PM Parts still for sale.
  9. Will do $75 for the box not including the boost bottle and electrical stuff.
  10. I already did it is on there for $49
  11. This is a pile of part that I have laying around after a Banshee Part out as you can see there are a lot of parts for a Banshee here. All parts are used and in usable condition. Any questions feel free to ask. Thanks. There is a lot of stuff here for a great price. $75 for everything listed below. Header pipes Set of mid section to exhaust with heat shields Extra mid pipe Ignition coil with fit all year banshee's 4 Axle Nuts Steering Stem mount clamp Coolant hose from cases to head 5 air box to carb mounting boots for intake Other misc rubber mounts/covers Swingarm pivot caps Swingarm pivot chain roller metal bushing Clutch lever and perch Front brake lever Clutch springs Kill/Light switch 1 black set of handle bar clamps 1 silver set of handle bar clamps Set of wrist pin needle bearings Oil dipstick TPS Controller Back Brake resivoir cap Little handlebar lever for Misc use. 2 Coolant overflow bottles Rear dogbone suspension linkage for shock/swingarm mounting Clutch Cover insert Water pump cover Renthal Racing Handlebar pad Fly Racing pad cover I also have 2 steering stems $25 a piece or $40 for both. ITP Sand Star Paddle Tire 20x11x8 for left side rear $30 Brand new still has all the nipples
  12. This is a pile of part that I have laying around after a Banshee Part out as you can see there are a lot of parts for a Banshee here. All parts are used and in usable condition. You will get everything you see in the picture I will make a list of most parts but there are a lot here so look at the picture. Any questions feel free to ask. Thanks. There is a lot of stuff here for a great price. I would like to get $175 for everything that is in the picture and listed below. Thanks, Will Duncan Racing Boost Bottle AC Racing rear bumper/grab bar Header pipes 3 random sprockets 41, 42, and 45 tooth Set of tie rods with ball joints Front brake master cylinder and lever Wiring Harness 1987-2001 square style connector 2 voltage regulators Ignition coil with fit all year banshee's Complete front brake line set Clutch Cable (maybe parking brake cable) Set of carb slides 2.0 size cut away and needles Parking brake Axle Nuts Steering Stem mount clamp Engine mounting brackets (an extra set of front mounts too) Other brackets for radiator Swingarm pivot chain roller Clutch cable holder Stator mounting plate 2 Clutch levers and mounts YFZ 450 Parking brake lever Rear sprocket hub Coolant overflow bottle Rear dogbone suspension linkage for shock/swingarm mounting Clutch Cover insert Water pump cover Set of Footpegs Fox Racing Handlebar pad
  13. $125 for all the stuff.
  14. Anybody want to make me an offer?
  15. This is also on Ebay right now for $99 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130345743355&ssPageName=STRK:MESELX:IT Here are a few more of my auctions on ebay too. Banshee plastic $29 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130345744138&ssPageName=STRK:MESELX:IT ITP Sand Star Rear left tire brand new 20x11x8 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130345738354&ssPageName=STRK:MESELX:IT
  16. This is a pile of part that I have laying around after a Banshee Part out as you can see there are a lot of parts for a Banshee here. All parts are used and in usable condition. You will get everything you see in the picture I will make a list of most parts but there are a lot here so look at the picture. Any questions feel free to ask. Thanks. There is a lot of stuff here for a great price. I would like to get $175 for everything that is in the picture and listed below. Thanks, Will Duncan Racing Boost Bottle AC Racing rear bumper/grab bar Header pipes 3 random sprockets 41, 42, and 45 tooth Set of tie rods with ball joints Front brake master cylinder and lever Wiring Harness 1987-2001 square style connector 2 voltage regulators Ignition coil with fit all year banshee's Complete front brake line set Clutch Cable (maybe parking brake cable) Set of carb slides 2.0 size cut away and needles Parking brake Axle Nuts Steering Stem mount clamp Engine mounting brackets (an extra set of front mounts too) Other brackets for radiator Swingarm pivot chain roller Clutch cable holder Stator mounting plate 2 Clutch levers and mounts YFZ 450 Parking brake lever Rear sprocket hub Coolant overflow bottle Rear dogbone suspension linkage for shock/swingarm mounting Clutch Cover insert Water pump cover Set of Footpegs Fox Racing Handlebar pad
  17. I would rather not bother shipping it but would be willing to do it is you pay shipping.
