kawa110 Posted February 15, 2017 Report Posted February 15, 2017 (edited) Is this possible? I do not want a digital. I want to see the needle. This POS 650 has one... Edited February 15, 2017 by kawa110 Quote
trickedcarbine Posted February 15, 2017 Report Posted February 15, 2017 Yes it's possible. Ya sure you really want one? 1 Quote
kawa110 Posted February 15, 2017 Author Report Posted February 15, 2017 Not if I have to give up my banshee. I allready have one in my s-10. I should have rephrased I guess.... Is there a way to hook a analog tach to my banshee that will rev past 10k? Quote
hoppedupandcutdown Posted February 15, 2017 Report Posted February 15, 2017 PM sent through here 1 Quote
Strm Trpr Posted February 15, 2017 Report Posted February 15, 2017 This is interesting, I'm in for the discussion. Quote
RagunCajun Posted February 15, 2017 Report Posted February 15, 2017 (edited) Same here. I wouldnt mind an analog tach since all the digital ones like the vapor are crap. I could get a guy in my shop to machine me a clean looking mount for the tach and a TTO inline temp gauge i want. Edit: I talked to the guy and he will make a holder for the gauge if i want. He's done many for some custom choppers. I also thought about a 2 1/8 or 2 5/8 water temp gauge instead of the TTO. Edit2: Wouldnt a tach that works with a 4 cylinder car(obviously 4 stroke) work with a banshee? The inline fours like a honda are firing every other time(1 and 4 are at top and 2 and 3 are at the bottom). Our banshees are firing every time on both cylinders. Edited February 15, 2017 by RagunCajun Quote
375hp banshees Posted March 12, 2018 Report Posted March 12, 2018 Definitely doable. can't remember the setting tho, so not much help there but..... this is a bad view of my temperature gauge too, just for ideas. I took the center radiator cover screw out, drilled a hole in the center of the two bolt mount and ran there ( to a "T" in rad hose) I used a piece of gasket material between bracket and cover . with one bolt it could shift a little, and scratch your cover, if you're worried about it Sent from my LGMS428 using Tapatalk Quote
kawa110 Posted April 27, 2018 Author Report Posted April 27, 2018 I want one for my klx110 also Quote
Toybreaker Posted April 27, 2018 Report Posted April 27, 2018 https://www.google.com/search?q=rd350+tach&tbm=isch&source=iu&ictx=1&fir=9ZxQhQgfjykjLM%3A%2CtZrRI1-TAOo6wM%2C_&usg=__Cq5BTAq4mMsrR3B2Lhsr8QG33S0%3D&sa=X&ved=0ahUKEwi_uqTU5traAhXHmeAKHd4-DAoQ9QEI1AEwAg#imgrc=xv7IjL4OEcygsM: aren't rd 350's the same? why not adapt one to the banshee? Quote
375hp banshees Posted April 27, 2018 Report Posted April 27, 2018 https://www.google.com/search?q=rd350+tach&tbm=isch&source=iu&ictx=1&fir=9ZxQhQgfjykjLM%3A%2CtZrRI1-TAOo6wM%2C_&usg=__Cq5BTAq4mMsrR3B2Lhsr8QG33S0%3D&sa=X&ved=0ahUKEwi_uqTU5traAhXHmeAKHd4-DAoQ9QEI1AEwAg#imgrc=xv7IjL4OEcygsM: aren't rd 350's the same? why not adapt one to the banshee?You just have to buy a tach with multiple settings. just like a handheld mechanic tach... 2 stroke 1cylinder, 2-stroke 2 cylinder, 4 stroke 4 cylinder...Sent from my XT1080 using Tapatalk 1 Quote
ClaudeMachining Posted April 27, 2018 Report Posted April 27, 2018 Digatron.Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote
375hp banshees Posted April 27, 2018 Report Posted April 27, 2018 << slow enough so he can see that little screen Quote
ClaudeMachining Posted April 27, 2018 Report Posted April 27, 2018 Screens are big enough, they look smaller on the pic.Plus, you can program the LED lights, Wich are easy to see.Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote
