Sheedawg28 Posted March 25, 2016 Author Report Posted March 25, 2016 How much was the skid plate? Prm has perfect fitment I bought mine from T&T atv for $125. Right, I'm sure there's others that fit perfect but not made of the light weight kevelar/plastic material which I wanted to keep the bikes weight somewhat down. Plus they ended up hooking me up so I'm glad I bought it haha. Quote
Sheedawg28 Posted March 25, 2016 Author Report Posted March 25, 2016 (edited) And I have red on my bike Sent from my SAMSUNG-SM-G890A using Tapatalk Gotcha you pretty much have them all the colors covered. The black is the stiffest one they sell and they have a green one now meant for kids I guess which is softer than the blue. Those look to be the compression elastomers you don't have the option to run the rebound elastomers? I know the older bars only had one which is why I'm asking and you can upgrade to the new set up for under 30 bucks. Edited March 25, 2016 by Sheedawg28 Quote
bluebanshee98 Posted March 25, 2016 Report Posted March 25, 2016 I bought mine from T&T atv for $125. Right, I'm sure there's others that fit perfect but not made of the light weight kevelar/plastic material which I wanted to keep the bikes weight somewhat down. Plus they ended up hooking me up so I'm glad I bought it haha.If your happy with it that's all that matters. I'm not sure of the weight on the prm. Would depend on thickness of the plate Sent from my iPhone using Tapatalk Quote
Sheedawg28 Posted March 25, 2016 Author Report Posted March 25, 2016 If your happy with it that's all that matters. I'm not sure of the weight on the prm. Would depend on thickness of the plate Sent from my iPhone using Tapatalk Definitely, plus we needed a test dummy as I haven't seen anyone run one on here. So we'll see how it holds up. Yea after buying the .190 swingarm skid plate I was dreading putting on a full engine skid plate of he same thickness but definitely the thickness of it would play a big part. Quote
sheerider11 Posted March 25, 2016 Report Posted March 25, 2016 Gotcha you pretty much have them all the colors covered. The black is the stiffest one they sell and they have a green one now meant for kids I guess which is softer than the blue. Those look to be the compression elastomers you don't have the option to run the rebound elastomers? I know the older bars only had one which is why I'm asking and you can upgrade to the new set up for under 30 bucks.now that I think about it, I should have 4 of each. I have 4 red. Guess I just have to order more or mix and match. Quote
Sheedawg28 Posted March 25, 2016 Author Report Posted March 25, 2016 now that I think about it, I should have 4 of each. I have 4 red. Guess I just have to order more or mix and match. Yea unless your happy with your set up then there's kind of no need. If anything you have the elastomers that have the most impact which is for compression so you can try those out before buying the rebound. Quote
Sheedawg28 Posted March 25, 2016 Author Report Posted March 25, 2016 Here's the JL engineering grab bar mounted. Still have to get a good picture of the throttle also. Never posted that up either. 3 Quote
0sikshee Posted March 25, 2016 Report Posted March 25, 2016 Here's the JL engineering grab bar mounted. Still have to get a good picture of the throttle also. Never posted that up either. John makes some nice stuff! Quote
trickedcarbine Posted March 25, 2016 Report Posted March 25, 2016 Tried loosening all the u bolts on the skid plate and clamping it where you want it, then tightening up the u bolts? Quote
Sheedawg28 Posted March 25, 2016 Author Report Posted March 25, 2016 (edited) Tried loosening all the u bolts on the skid plate and clamping it where you want it, then tightening up the u bolts? Yea it wouldn't budge once I would tighten it down, the way the clamps grabbed the frame would make it come down. TM is sending me a clamp to replace the one that doesn't wrap around all the way so that it clamps all the way around it and keeps it in place which would solve that issue. I'll keep you guys posted. Edited March 25, 2016 by Sheedawg28 Quote
Sheedawg28 Posted March 25, 2016 Author Report Posted March 25, 2016 I did read that it would take form of the bike being plastic/Kevlar so maybe now that it's been on for some time it's taken a bit of form and I can move it up a little bit. Quote
Sheedawg28 Posted March 25, 2016 Author Report Posted March 25, 2016 Heat gun That would definitely do it. After looking at it closely. If you look at the 3rd row of clamps (or second to last) the frame starts to curve in and those clamps when tightened down move the skid plate down because they aren't making full contact, so when I tighten those down it moves the skid plate down to where it is making full contact which is where it sits now. So the issue might be the placing of the pre-drilled holes in the skid. Hopefully that makes sense I'll take a better look at it and try loosening and tightening it down again when I get home..this is just my assumption based on the pictures I have. Quote
Sheedawg28 Posted March 28, 2016 Author Report Posted March 28, 2016 So I tried out the funnel, took it with me to fill up the fuel tank annnnd here's what I got out of it. I might be buying the biggest version and using this for when I fill up my vehicles. Mind you this was clean before fueling up. Quote
LaegerEliminator Posted March 28, 2016 Report Posted March 28, 2016 So I tried out the funnel, took it with me to fill up the fuel tank annnnd here's what I got out of it. I might be buying the biggest version and using this for when I fill up my vehicles. Mind you this was clean before fueling up. Do you have a before pic? Quote
