Manny's MX build
I like the linkage from Elka but its too wide to fit in PRM's skidplate, I even asked them to make one 1/4 of an inch deeper. no dice. it literally needs less than a 1/4 inch to fit. good product though.
I got my Ella linkage to fit into a prm skid plate. I think the collar on the spring was all the way up. ( shock was setup for a longer arm) but it's in there
I took a grinder to my skidplate to make it fit originally because of the -2 arm hitting the stock linkage. Don't be scared.
  • Like 1
im not scared, but ive cracked the u channel off one, and im working on the second. the linkage scrapes somewhere in the travel, 2 groves were worn in the bottom of the channel. it like a paper thickness clerarance at rest. That's with the stainless plate removed too, and some smoothing of the edges of the anodized link
Edited by Scrubby
Slap a GoPro under there with a bicycle mount and see why it's acting up so you can rectify the issue.
