wayne_smith97
    6
Everything posted by wayne_smith97
  1. Slide needs to come down til it clacks, with idle screws backed out. Then adjust idle from there.
  2. http://atlanta.craigslist.org/nat/mcy/5137704232.html Bike just about sold itself. Ad screwed up the sale
  3. I do know that it will spit em out as fast as I can pull the trigger
  4. I have no complaints yet either. Not many rounds shout though.
  5. http://www.google.com/imgres?imgurl=http://www.lcracing.co.uk/images/2013-12-22-nice-clutch.jpg&imgrefurl=http://www.lcracing.co.uk/page_21.php?pgenme%3Dwiblog&h=667&w=1000&tbnid=nbf-ajDIMTVjIM:&docid=zFkCSrmEfu4IeM&ei=l7ayVaKKKseF-gHe2JTADw&tbm=isch&ved=0CD0QMygVMBVqFQoTCOKxkJXj9MYCFceCPgodXiwF-A
  6. There should be another nut.
  7. You do have the jam nut on it?
  8. I've had a glock. The Springfield xd I have now feels soooooo much better.
  9. Make sure you're synced at about 1/4 and 1/2 throttle also. You can check by by making sure they lift off the bottom at the same time or by using the sync tool
  10. You can raise the idle. It will in turn bring up the vacuum number. Set your idle where you like it and just make sure they are pulling the same vacuum.
  11. Doesn't really matter as long as they are equal
  12. Is this moron g?
  13. I guess we've all been putting the wrong combination of parts together
  14. http://bham.craigslist.org/snw/5071405096.html
  15. https://memphis.craigslist.org/snw/5111697208.html Might interest someone.
  16. You could try another flywheel. If you got a buddy with a banshee
  17. Is the key sheared? Is the flywheel rattling? I've only had one bad flywheel and it didn't bog. Hell it didn't start
  18. It shouldn't have any jiggle at all. Post a video.
  19. Then you should really tear the carbs down and clean the crap out of them. Get all parts out of the and boil them. That's what I do. If it just started it then chances are that the carbs are dirty. Once you get the carbs off go ahead and leak down test it. Cheap insurance. Would hurt to check compression too.
  20. Set your af screw to 1 1/2 turns out if the bog doesn't go away, start turning it out a 1/4 turn at a time. If it gets better the pilot is too big. I know fmf calls for a 30 pilot, but your air box is still on and you're not ported. Check on pipes. Gnarly, sst or fatty. Also this is assuming your carbs are squeaky clean.
  21. Need to double check that pilot size. It's should be either 25, 27.5 or 30. Does air box still have the snorkel? I take it that you stay under 1500 ft of elevation? You either have fmf gnarly, fatty's or sst. Not sure they made a rev pipe for banshee.
