ticktock
Everything posted by ticktock
  1. Never heard of LRE. I assume it was not a duneable? Adam
  2. Is your other Override the WCR Pro mod you are selling?
  3. according to the DMC website the picture of their banshee with the older style light vs. yours. The mid pipe crosses the frame to the silencer in the same spot or close to the same height. The only difference I see between the two are the rubber bushings to mount the silencer - they are important. solid mounting can cause weld fractures. The other difference is you have a brake light, where theirs only has a tail light. pictures for reference http://www.dmc-on-line.com/index.php?main_page=product_info&cPath=67&products_id=323 Any leak in the exhaust between the engine and the silencer is a potential for inefficiency. The two stroke gets its power from the unburned fuel in the exhaust and mixing air into the system has the potential for power loss. Is it a big deal? No, but I would do my best with trying to seal it up. Adam
  4. JD's Customs did a great job on the POW/MIA Banshee Grill. Just showing off his work! Next step is one of his Shrouds and Gas Tanks. Also going to send my Fronts to him for a little aquafusing to draw all the attention to the flag. As you can see in the installed picture on the bike the center mount covers up the "You are not Forgotten" If he would have made it any smaller than it would not have come out correctly and unfortunatly my time in the states has rapidly come to an end. When I get back in a year, JD will be helping me finish up the look during my complete make over! Thanks JD
  5. I think no limits had them for 80 a set back when they were M&M Adam
  6. Rootracing has all Chariot products. Pm him for more info.
  7. If you are going to replace studs in the cases heat that case up to 200* in the oven. You are going to be breaking studs and they are a bitch to drill out.
  8. I bought new tired rims and a set of 4/115 hubs for right around 225$. 9" give you more options. I bought kt335's
  9. Which I would like to add is cheaper than a new oem cylinder. Then sell your new pistons here or eBay.
  10. Sold pending payment Adam
  11. Bump for Quadpro, guy ships fast as hell. Buy with Confidence here!!! All his parts are quality! Adam
  12. Don't you owe me axle money?
  13. Shift Drum, Ported cylinders sold
  14. How do you ship things cheaply overseas? I had a couple of offers on my pipes but shipping to australia seems to be crazy expensive? While shipping to Canada seem cheap in comparison. What have others found the best/cheapest way to ship to remote locations from the US? Thanks, Adam
  15. its going to cost over a 100 to ship to Australia. I was going to pay for shipping at 350 but overseas $425 Adam
  16. Hi!, Welcome. First off, dont listen to half the assholes around here. You cant expect must of the guys that have heard it all! As long as you are just looking to get a little bit more out of you shee and not trying to go 100 here are a quick list of what I know Vito's Super stock pistons (you cant port your cylinders at all with this) 8hp +4 timing 2.5ish hp across the curve Welded crank 0 Mods to improve performance: Porting Larger carps Different pipes Aftermarket cylinders These are just a few of the performance mods that a lot of the guys here make. #1 is porting, rejetting and getting your crank welded. Higher hp causes the crank to separate which is bad! If you have questions about who what where when use the search function and you will find the answers you are looking for. Welcome to the site again and hope you find what you need. Take everything with a grain of salt and understand that the banshee brotherhood starts with a "fuck you" and ends with "we will always be here to help." Adam
  17. FMF made two pipes, a woods and rev pipe. Have to look through old dirt wheels to find out what ones. Adam
  18. Cut the rotor off and toss that shit! use a vise grip to take the bolts out.. Metabo discs rule! Adam
  19. Call Camatv if you want to cut gears. Have someone do it that knows the business there. Adam
  20. Brandon and Jeff will get you both going in the right direction. Either will answer your questions and make sure that you are getting exactually what you want. Most importantly they will set you up with the best performing machine. I have no experience with HJR, but their motors run strong. It's all about dealing with who you click with. Sounds like you know you are going 4mil in the future so keep an eye out for a 4mil crank!! There have been a few forsale lately. Adam
  21. No you cannot run the boost bottle with 2-1 setup
  22. Yes rejetting will be required but not a lot higher than what you have now. Adam
  23. Neutral is down because the drum is cut. The cutting of the drum allows the bike to drop into neutral. So its N 1-6. Think about opening your mouth when you have no clue.
  24. Bump! KFX Needs a DASA!!
