xjmav
1 Follower
About xjmav
  • Birthday 11/10/1987
Contact Methods
  • Website URL
    http://www.toysbytroudt.com
    Denver
  • Interests
    Hillclimbs, dunes, going fast and water!!
    96 red banshee. Under build Fmf pipes, Cool head, 18cc domes, v force 3 reeds, custom extended swingarm
xjmav's Achievements
HQ Soldier
HQ Soldier (2/5)
5
  1. How much for stator with out timing plate? Already have a plate Sent from my iPhone using Tapatalk
  2. Yes sir, that's why I have a new one on the way. Sent from my iPhone using Tapatalk
  3. It was hit passenger rear, bent rim, bent axle, fucked up plastics, broke exhaust popped exhaust springs. Threw me a good 30 ft. Kid was climbing a long ass hill with no spotter, cleared the top probably 3rd on the pipe and never let off. Hit me a good 50 yard from the crest of the hill. Took 4 guys to separate the bikes and another to help me back on. Worst part is him and his father ended up running and left me with a destroyed shee, a busted hip and a ruined vacation. Was the first full day of a 6 day vacation. People suck Sent from my iPhone using Tapatalk
  4. Ignition coil was at 17.8, pickup was at 117 and lighting was at .6 Sent from my iPhone using Tapatalk
  5. What about stator? Can it weaken on the top end even if resistance checks out? Sent from my iPhone using Tapatalk
  6. I cut and eliminated tors and parking brake. Years ago. Float height was set last ride, I suppose it wouldn't be bad to check again. My uncle has been building banshees for years said it acts like a rich condition and that's the basis of the jet changes. 3000 ft elevation change from last riding location, went down 2 jets. I have the new style CDI plug and a new stator to harness plug on the way. The stator plug melted the clip together from the accident. Wasn't shorting though. Pulled wire harness out and pin to pin everything. All wires check out and nothing shorting to another wire. Once I change/ fix plugs I'll be able to swap electrical components. Sent from my iPhone using Tapatalk
  7. Ran the same way with a brand new toomey 2 to 1 filter like new out of the box Sent from my iPhone using Tapatalk
  8. I believe I should be closer to 120- 130 . I know it's time for a top end but it was like a light switch. I was t boned and then it ran like crap. Won't get on the pipe and bogs at top end. Runs amazing getting there. I'm still suspicious of a weak stator, was warming up checking heads with my hand and it shocked the hell out of me on the left jug. Stripped and repaired all the plug wires and caps. Have a whiteish spark on the left jug didn't check the right jug. The 300 mains were at about 6000 ft, it ran its best at 9000 ft with 280s but at the top end sounded almost like a revlimiter was kicking in. Just flat stopped pulling. Then it was like someone was turning a switch on off on off. Power no power Sent from my iPhone using Tapatalk
  9. Yes, and verified multiple times. Sent from my iPhone using Tapatalk
  10. Having top end issues. Bike starts great runs great sounds great. Has no top end feels like it just hits a wall and falls on its face. Was running amazing last year on 300 mains and 27.5 pilots needle on second clip from top. Running 6000-9000 ft typically. Replaced coil and plug wires. Played with jets from 290 all the way to 190 and never got better Carbs in sync, tors deleted, did leak down test and all good. What do I check from here? I know I have lower compression, 90L 92R. Resistance on stator checks out. Haven't had a chance to swap CDI yet it's a 96 all the other shees we have are 97up or pre 95 18cc domes on a cool head, +4 timing, toomey t5 pipes, boyseen dual stage reeds, k&n pods, welded and trued crank, NOT ported yet. Will be ported and a fresh top end this year Sent from my iPhone using Tapatalk
  11. Looking for a good set of force 4 reeds. Need by the weekend please Sent from my iPhone using Tapatalk
  12. Hahah top of the line everything. Bet those are high dollar power band pipes
  13. Yamaha Banshee 5k Aftermarket, better than new!! $2250 http://denver.craigslist.org/bar/4666283557.html
  14. ***2005 YAMAHA BANSHEE TWIN 350*** - $1 http://denver.craigslist.org/snw/4610251522.html Just had plastics powder coated
  15. I got her to idle last night with 25 pilots, 1.5 turns on air screws. Just bought 27.5 pilots and 280 mains. 21 bucks for all four! Sent from my SM-G900T using Tapatalk
