Zwiser
Everything posted by Zwiser
  1. ok i have a bunch of different size jets for these so i start here and adjust as needed. im kinda worried about runing the LGN needle though because i never hear of any one using that one, only JJH and N68A
  2. Ok so im finally ready to throw these pwk 28s on after getting the stock carbs pretty close. what i have for jets in the pwk's are 45 pilot, 145 main, LGN needle on middle clip, does this sound close for my mods below? the lid is off BTW no airleaks and comp is at 160 psi, with fresh 93 pump mixed at 40:1 with klotz ST
  3. Just got my rotor from JD in the mail, and its top notch!
  4. I have one on mine. i bought it off ebay for like $8
  5. what reeds are these for?
  6. Zwiser
    G-force axle
    i have a modquad one that is like that except its double locking so it has two allen bolts, if i got one would i be able to use that nut on the axle?
  7. Zwiser
    G-force axle
    how is their locking method fucked up?
  8. Zwiser
    G-force axle
    How do they adjust? are they like collapseble, or have like hub adapters?
  9. if you didnt ride it you should be fine
  10. this is what my plug looked like after i did the plug chops in all the throttle ranges, this is alittle rich and the pilot is the richest because the tip is slightly black. tip of the electrode = pilot jet middle of the electrode = needle bottom = main
  11. loose the boost bottle, they cause your intake boots to crack. And stock banshee suspension sucks. So coming from a ltr you might not like it so make sure you test drive it before you buy it.
  12. could i see some cleaned up pics of the calipers?
  13. Just buy one from the dealer, they should have them in stock.
  14. Are you willing to part it out?
  15. just get your current t5s chromed
  16. glad you got your money back but i can see how your pissed at him for lying but for $65 what can you expect?
  17. Zwiser
    Hiper tech 3
    looking for some used hiper tech 3s, perferably beadlock but ill take some non beadlocks
  18. these were the ones i was looking at before i started this thread. idk if i want to drop the big bucks right now for a set of hipers, as im saving some money for a winter build now.
  19. bead locks or non bead lock hipers? this is just for woods and trail riding
  20. What kind of wheels do you guys run in the woods and trails that last the longest? Ive tried itp t9s but the seem to bend easy around the lip. also whats the best? itp bajas? bead locks? rolled lip? etc etc
  21. Zwiser
    Bent axle?
    Well, when i was putting my new +2 swinger on i realized my axle woobles like 1/2 an inch. i can also hear it when ever i spin it fast. Will i harm anything by running it? i dont know if it was always like this or if it happend when i had it all apart some how?
  22. wheres the second line go??
  23. is it for a stock swingarm? whats the weight set at?
  24. I believe this is normal...
