Zwiser
Everything posted by Zwiser
  1. sorry man i cant get the dip stick had to buy other stuff...
  2. knowbody knows?
  3. If the carbs are stock thell probably have boxes on top with a idle screw, if the don't have the boxes look at the model number I think it's like vs 26..........
  4. there not desighned to run inlines, but people put them on for added protection. Did you clean your petcock in awhile?
  5. Zwiser
    A Arm play?
    thanks for the link...
  6. Zwiser
    A Arm play?
    Ok I don't plan on riding it for awhile anyways because the chain slider is worn down to the frame
  7. Zwiser
    A Arm play?
    When i jacked up the shee and turned the bars it pushes the a arm on that side back and the other forward and vise versa what would cause this? Bad bushings? Bent frame?
  8. pm sent....
  9. I got a set of blaster works shocks set up for my weight. I put them one but im wondering since the shee is heavier would it bottom out going over bumps and jumps on the trail?
  10. Hello, i just got a shee today and while i was ripping it down to inspect i found a k&n air filter in the airbox with the lid on and a boost bottle everthing else is stock. What should my jetting be 300-1000 ft sea level right now theres a 200 main in both
  11. if it starts taking off at wot cant you just hit the kill switch?
  12. ok well i plan on redoing this thing all correct and i have a few questions about this shee should i post them in here or in a different thread?
  13. why whats wroung with them?
  14. i got it today, comp was 120 in both cylinders, it has a kn airfilter and a boost bottle, also i noticed there was oil on the engine skid plate and i located the area where its coming for its a little raised circle hole by the drain bolt, is there soppused to be a bolt in there?
  15. i checked the play in the front suspension and the wheels have slight side to scid play. and i did ride it just up and down his drive way tho fisrt it started to feel like there was resistance in it but then it died but the fuel was off so i guess it just ran out of gas so i put it on and it fired back up and was no resistance
  16. mods to the blaster are: • La/ct big bore kit • Front itp c series sport rims • Rear itp t9 rims • Rear kenda kutters • Front holeshot exct • Ebc dirt digger clutch • Pe billit clutch basket • Ac racing front bumper • Works shocks front and back but im keeping the fronts for the shee • Did 520 ert2 gold chain • 14-40 gearing • Mod quad oil filler cap • Polished billit throttle cover • Keihin pwk 35 • Throttle cable • Clutch cable • Pro taper SE bars • Allen head bolt kit • Vitos degree key • New uni air filter • Toomey b1 exhaust kit • Ac racing grab bar • Ac racing nerf bars also its a straight up trade
  17. i did stand on it and shack it a little and there did seem to be some play but i think it was the foot peg mount, also when i get it i want to make sure its safe to ride on, what all should i look for, i just ride in the trails and strippings here in pa
  18. im trading my blaster for it.
  19. i did check and there are no cracks in the frame, but what about the rattle is that normal?
  20. Guy said it was bored .40 over with ten hours on it, he did the work his self, there seams to be some sorta resido around the gasket meeting surfaces on the out side, but it was dried up and wouldnt come of by scratching it, theres one small crack in the plastics by the raditor, the rad is dented in some near the bottom, it starts in one kick, when i rode it there was a rattle it wasnt coming from the engine but you could easily hear it, there were no knocks or anything sounded good, but the left foot peg area was wobbling but the bolts wernt in the whole way but he said they wouldnt go in further after he put the nerf bars on, also the part where you screw the throttle cable in is broken so ill have to order a new one
  21. guy said its all stock engine and exhaust, but it has nerf bars and skid plates i bring a compression tester it should be over 120 right? in each cylinder, and ill be making a leakdown tester for it also. I plan to keep it mild till i get used to all this power, just some pwk 28s maybe pipe it, cool heads, billet water impelor,new grab bar and bumper, its a 1999 btw and looks really clean, doesnt have any wear from the boots rubbing on the frame either and i cant see any rust either from the pics
  22. Hello, im new here and im going to look at a banshee tomorrow and getting it somtime this week. Is there anything i should know about banshees? Thanks
