rb0804
Everything posted by rb0804
  1. On a stay-cation? LOL. I am guessing that is going to stop the engine from trying to pull towards the rear sprocket and take some stress off of the cases? This is the first time that I have seen something like this, do a lot of guys in MI a similar getup?I would think that the motor mounts would do a good job of keeping the motor were it needs to be and that the bearing support would take most of the load/stress off of the cases. Maybe I'm wrong or maybe its just cheap insurance. Thanks for the photo and good info Dave.
  2. I would like to see some pics of the tranny right after you split the cases, before you really touch anything so we can see what happened. Got any pictures Dave?
  3. I believe that the aluminum gear was designed with the same intentions.
  4. Only thing I could find, never been there: http://www.pittsburghracewaypark.com/index.php
  5. I ordered all three, the pump, gear, and shift star. I am eager to get out and try the shift star. We had a little mix up on the parts but Brandon immediately fixed the situation. Great customer service. Thanks
  6. A complete billet trans like the one WCR sells or just a billet second gear? What is the upper HP limit of the stock type tranny?
  7. Does anyone know where you can purchase the extension ring to mod the stock cover for a lockup? There used to be someone who sold the ring and the lockup together, but I can't seem to find them. Thanks in advance
  8. PM sent
  9. Has anyone tried Trinity's OOF racing pipes? Anyone know the port durations that they were designed for? Thanks for any input. I saw this set on ebay and was curious Thanks http://cgi.ebay.com/ebaymotors/Banshee-Rasing-Drag-Pipes_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem439a624b5cQQitemZ290352941916QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
  10. tranny still available?
  11. Do you still have the white cut front fenders? How much shipped to 19802? Thanks
  12. Are the foward A-arms help with weight transfer? I already have a +6 swingarm and am going to be in the market for a round house in the future. Would it be better to add the 2" to the swingarm or hang the extra 2" out of the front with the A-arms? Racing on asphalt. Thanks
  13. You can only replace shift forks for so long. Once the groove in the slider gear gets worn it doesn't matter how many sets of shift forks you put in it, its going to tear shit up.
  14. Any updates yet??
  15. Sold
  16. stock banshee axle for sale. good threads, should clean up nice. asking $50 plus shipping. Make me an offer http://s290.photobucket.com/albums/ll253/rb0804/other/
  17. Probably 14's your not going to have much MPH with a 13 tooth sprocket. There is only one way to find out.
  18. there should be an oring in each pipe. They do not come from Matt with them in there you have to locate and install them yourself.
  19. It works...In general the engine doesnt like being on the two step too much. You also need to fab up a switch to activate it off of the clutch lever. I use a FBG prostock lever
  20. why not?
  21. Do they use banshee reeds or blaster reeds? The reeds will work with nitrous as long as they are not carbon fiber. I understand that you did some extensive testing on your cage/reed setup. Would it be cool if I shot you an email to sort of discuss findings and data? Thanks
  22. Any one tired these? Do they work well? Do you use a rubber coating for the reed to seal/bounce against or is it just aluminum? How do they compare to stock ported cages? Looking for a good alternative to the vf2's for running nitrous.
  23. Anyone try using an override drum on a non-override tranny?
  24. Are the reeds in when you do this? If you have the pressure tap in one intake and the gauge on the other, The reed valve should stop the air from entering into the other intake boot right? That is what a reed valve is a one way check valve?
  25. 1-5 neutral down duneable
