98_shee
Everything posted by 98_shee
  1. Here's a pic on mine its an a-arm frame. ASR +2 up 1 with elka's
  2. Are you running a spacer plate or cut domes with the 4mill? I have a pro design head with 18c dome's cut for a 4mill that i don't need.
  3. I have one I got with a bunch of parts I bought. $20 shipped
  4. You had a feeling the choke is supposed to be connected?? The choke is in the side of the left carb and the choke tube is on the opposite side of the choke it is a small black tube that connects the carbs. You need a clymers manual.
  5. No, there is an adjustment for the shift shaft. What the problem? Post a new topic in the repairs and mods section.
  6. Pistons arent something i would take a chance on. I would spend the extra money for a quality set.
  7. When your ready to buy some parts let me know. I have a set of holeshots that are almost new, a few billet odds and ends, and a set of blue tag fat bars with clamps.
  8. Did you put the choke tube back in?
  9. Backfiring is normally a sign of a lean codition, did you do a leak down test to check for air leaks? What are you mods, elevation, temp, current jetting?
  10. I have the msr shorty easy pull on mine with heavy duty clutch springs and it works great. I have an extra one if you need it pm me. Welcome to the site
  11. Welcome to the site. Im in north west AR not to far from you, if you need any parts or help you found the rite place.
  12. I agree with badjetman. If you have to choke it when its warm it may be low on compression. 30 pilot sounds rich for your mods.
  13. Welcome to the site. Still running the stock filter, any mods to the airbox? If not I would start around 260-270 and work down from there with stock pilot jet.
  14. If the hubs fall through i have them, heel guards but one has a tab broke off and i may have a taillight. pm me
  15. I always left the hole open. Not sure if thats rite or not.
  16. I have a set of asr +2 +1, pm me if your interested and i'll get some better pics.
  17. No need to pull the pipes to see if they have fuel in them or drain the cases, if your pipes or cases are full of fuel you have a more serious problem. Start by checking the basics, fuel, spark.
  18. Bought a few things off yamahaman244 everything went smooth. Good guy to deal with.
  19. What kind of swinger is it?
  20. If you find a set of jugs, i have 2 sets of pistons boths are 64.5 one set for stock stroke and the other is for a 4mill and only have a few hours on them. Pm me if you need them.
  21. I may be interested in it also, if it will fit an '04 gmc duramax.
  22. I have a set of aftermarket reeds. Pm me.
  23. Plastic Renew also works great.
  24. 98_shee
    pipe hanger
    Pm returned.
