Building my First
Everything posted by Building my First
http://www.bansheehq.com/forums/index.php?showtopic=115511
Parts are from a pretty clean 87. Everything is in good usuable condition. All prices include shipping in the USA, unless stated otherwise. USPS Parcel Post unless Priority is within a dollar or two. Will ship worlwide at actual cost. Please include 3% Paypal Fee with your payment. Paypal ID is: [email protected] PM me with any questions or if you need something you dont see. Click the photobucket link for pictures: http://s636.photobucket.com/albums/uu89/aj...e%20Part%20Out/ I might be adding the cylinders if my buddy doesn't want them. They are .020 over and have .004 of wear so the will need to be bored, stock porting. If he doesn't take them they will be $215 shipped. Engine & Trans Carbs with tors $55 Cases $130 ( The top half has been repaired due to chain break, did not break the trans just the flange. They have a clean up port, they did not cut into them very much, just cleaned the sharp edges.) Clutch Actuator $15 Clutch Basket $60 ( Inner hub and pressure plate are in great shape, outer hub has some dogging and the cushions are worn, nas about 1/4" of play.) Clutch Set $15 ( Used OEM style with the dampners, look like they have some life left, figure they would get somebody out of a jamb.) Clutch Side Cover $35 Crank Shaft OEM $160 ( Was told it was rebuilt a couple years ago. Bearings are tight and turn smooth, side gap on rods is <.040 .) Cylinder Head $20 ( Nice, no pits or gouges in the domes.) Gear Sets $75 ( 2 sets, 2nd gear is shot on both primarys nad on one of the secondarys, all the others are good.) Kick Gear $15 Overflow Bottle $10 Mag Side Cover $20 Radiator with hoses $25 Shift Drum with Forks $30 Water Impeller $15 Electrical CDI Box & Regulator $50 Coil $15 Flywheel $35 ( Did not come off this crank, came from a guy on here. It is a little beat up but still usable.) Headlights $50 ( Each has one of the little corners boke, on the grills.) Key Switch $30 Kill Switch $20 Stator $50 Wire Harness $25 Plastic Fuel Tank $25 ( Will seperate petcock if thats all anybody wants.) Rear Fender $65 ( Has scuffs and scratches and could use some scrubbing. No cracks.) Tank & Rad Cover $35 ( As you can see they are sun faded but no cracks or stress marks.) Suspension A-Arms $50 ( Threads on ball joints are not perfect but nuts go on with out cross threading or stripping. Ball joints are tight and bushings did not have any play.) Front Weel Hubs & Spindles $55 Front Shocks $40 J-Arms $40 ( Threads on ball joints are not perfect but nuts go on with out cross threading or stripping. Ball joints are tight and bushings did have a little bit of play.) Rear Shock & Dog Bone $50 Everything Else J-Arm Frame $50 ( Pickup only, unless you want a shipping quote and I know it wont be pretty.) DG Nerf Bars $45 ( Old steel style, one of the web tabs is broke and webs will need replaced. Otherwise the are in pretty good shape, no hardware.) Rear Brake Caliper & Master Cylinder $65 ( Brake Pads look like new, must be EBC Greenstuff, only green pads I've ever seen.) Rear Grab Bar & Light $15 Sprocket Hub & 45 Tooth $20 ( The sprocket thats still on the hub in the pic is junk, the 45 is like new.) Thumb Throttle $25 Tires 20x11x9 RAZR's $50 ( I will have to weigh them to get a shipping price.) Thanks for looking.
88 banshee for sale $800
Building my First replied to yamaha rider's topic in For Sale - Parts & Accessories
I have all the things you need, if you want to fix the J-arm frame. Let me know I will be taking pics of everything tomorrow. -
i guess .. i want more power ?
Building my First replied to yammyboy3's topic in Banshee Repairs and Mods
With those cpi's you do need some 30-33mm carbs, maybe 35 since you want all top end. Now you need some trans work too, 1-5 dunable with a lockup and pancake is what your setup needs. -
Would Warrior fenders fit on banshee?
Building my First replied to xXBANSHEE_KILLAXx's topic in Banshee Appearance
Warriors aren't that bad, I ride the ol' ladys when I don't feel like going fast or I just want to ride a whellie all day. -
Retail on these are $180 and other good billet ones are around $140. So $80 is fair for the condition.
I have a set of Trinity Billet Intakes 33-35mm but 36's should fit without too much of a problem. The lowest I could go is $80 Shipped, I know it's higher than you wanted but they are worth 80 and in excellent shape. http://s636.photobucket.com/albums/uu89/aj...nt=101_1168.jpg
$125 shipped for the carb and manifold. You will need the carb boot ($45 on ebay), Blaster without TORS throttle cable (around $20), and an air filter. http://s636.photobucket.com/albums/uu89/aj...nt=101_1148.jpg
I had an issue with a flywheel I got from him a couple months back. Said he didn't have the cash to refund me then, naturally I bitched about it. He sent me $100 last night! Only had to refund $50, I guess I earned some good interest. Anyways he is a stand up guy in my book now.
Well yammyboy3 kept his word. He sent me $100 last night. He only owed me $50! So I sent him some shift forks for free.
I have most of what you need. http://forums.everything2stroke.com/vbclas...o=ad&id=285
Are You Kidding Me?
Building my First replied to 06specialedition's topic in Banshee Repairs and Mods
What is your pilots set at? Choke crossover tube on? -
pancake bearing w/ slingshot
Building my First replied to RagunCajun's topic in Banshee Repairs and Mods
The one from fast doesn't have #4. He should be able to set you straight. http://www.farmandsandtoys.com/partdetail.asp?partid=193 -
You should be able to squeeze 36mm carbs in these. http://www.bansheehq.com/forums/index.php?showtopic=114093
Found more parts I don't need.
Building my First replied to Building my First's topic in For Sale - Parts & Accessories
Make an offer, need to save for 450 arms. -
Reeds??
I have a set from a 2000, they were hard on 2nd though. Both second primary and secondary have a chip, other than that they are in good shape. Make a fair offer. If you need a certain gear I can pull it off for you.
$60 shipped USPS Priority Mail first thing in the am. http://s636.photobucket.com/albums/uu89/aj...nt=101_1172.jpg Don't recall the year, bought a parts lot off ebay a while back, came from a running Banshee until they ran it lean, thats what they said. He had 100% Positive Feedback
34mm Keihin and 2-1 Manifold
Still available. ^^ Guy bought his first Banshee and just needs to get his jetting figured out. He has FMF Golds with Pods, the guy he bought it from said it was jetted for winter still, but it had 200 mains in it! -
Trinity Stage IV Billet Intakes 33/35mm $80 Shipped http://s636.photobucket.com/albums/uu89/aj...nt=101_1168.jpg Modded Shift Star $25 Shipped http://s636.photobucket.com/albums/uu89/aj...nt=101_1170.jpg BOOST Bottles!! $15 Shipped Each http://s636.photobucket.com/albums/uu89/aj...nt=101_1166.jpg Shipping will be USPS Priority Mail to the lower 48. Worlwide is additional. Paypal ID is: [email protected]
http://www.bansheehq.com/forums/index.php?showtopic=114023 $125 shipped You will need the carb boot and cable, $45 for boot on ebay and $20 for a Blaster cable - tors.
I have a useable set of cases, has a crack under the sprocket but doesn't reach the trans. I also have a crank I got off ebay last year, was supposed to be rebuilt ( just needed to be trued), one rod is new but the other bearings need replaced. $100 shipped for both.
Come on guys, put the PJ on a beafed up Blaster.
