yammyboy3
1 Follower
    blue 2002 banshee lrd pipes .60 over
yammyboy3's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. seat foot pegs lights sold
  2. SOLD 35 pwk boss intake 66mm cylinders stock cylinders cpi inframe drag pipes noss head with domes
  3. cpi inframe sold 35 pwks sold boss intake sold
  4. everyone please send a text or call my phone so i can help you better this sending messages back takes way to much time! 856 264 6004 tony or a straight email to [email protected] i can only send pics threw picture message from my phone the a arms are yfz450 and so are the shocks the shocks are black and red all of this stuff is in great condition i just lost my interest in quads CPI INFRAMES SOLD
  5. 2002 BANSHEE FRAME WITH BILL OF SALE 300. +4 115MM ROD WIESCO CRANK 350. 66MM RUNNING TOP END WITH PORT WORK 300. NOSS PERFORMANCE HEAD WITH 20CC STROKER DOMES 180. 35MM PWKS WITH 6 INCH KN PODS 350. BOSS BILLIT INTAKE BUILT IN CROSS OVER TUBE 130. VFORCE 3 REEDS AND CAGES 150. CPI INFRAME DRAG PIPES SHOW CHROME 400 BOTTOM END CASES MINT ,, POLISHED 200. TRANY 150. HEAVY DUTY CLUTCH AND SPRINGS 130. MISC BOTTOM END GEARS 50. POLISHED CLUTCH COVER WITH BILLIT INSERTS 110. BILLIT WATER PUMP PRO DESIGN 40. KICKER 15 RADIATOR WITH HOSES 30 SKULL GRILL WITH POKER HAT AND JOINT WITH SHROUD 40 IMS 5.8 GALLON GAS TANK WITH PETCOCK AND BOLTS 200 SEAT NO RIPS 15 WHITE RACE CUT PLASTICS 100 HANDLE BARS 30. STATOR 60 CDI 50 FLYWHEEL 50 FLYWHEEL COVER 10 RICKY STATOR ADVANCED TIMING PLATE 30 WIRE HARNESS 50 IGNITION WITH KEY 30 HEADLIGHTS WITH BRIGHT BULBS 20 HEADLIGHT / ON OFF SWITCH 20 +2+1 A ARMS WITH RESIVOIR SHOCKS WITH +2 TIE RODS 375 BREAK SET UPS EVERYTHING FOR FRONT 50 BACK BREAK SET UP 75 SWING ARM 25 REAR SHOCK 30 STEERING STEM 50 AXLE 75 CARRIER WITH GOOD BEARINGS 50 HUBS 4/115 40 REAR LOWERING LINK 50 LINKAGE 10 CHAIN WITH 16T FRONT AND 40T REAR SPROKETS 40 ALSO HAVE 64MM STOCK BORE STOCK PORT POLISHED CYLINDERS 250 AIRBOX WITH KN AND ADAPTER 50 STOCK CARBS 60 THROTTLE CABLE 10 RED GAS TANK SHROUD 10 STOCK GAS TANK 20 AC RACING NERF BARS ALUMINUM WITH BLACK NETS 130. IF THERS ANYTHING ELSE ON A BANSHEE THAT YOU NEED LET ME KNOW I PROBABLY HAVE IT CALL FOR DETAILS THIS STUFF WONT LAST OR BUY THE WHOLE BIKE FOR 4000 856 264 6004 TONY
  6. FUCKING THIEF DO NOT DEAL WITH THIS ASSHOLE
  7. anyone interested in comin call or text 856 264 6004 bring EXTRA gas theres allot of trails and wide open paths
  8. these are all take offs that are in good condition i want to get rid of if you need pics just ask i have no problem sending you some polished head right cylinder has some markings in it clutch springs i think i have enough for 2 bikes +4 stroker base plate vitos i think shifter forks 2 air boxes pro flow airbox adapter billit stock timing plate rear caliper doesnt look to pretty 4/115 hubs tors stock throttle cable carbs with tors removed idle screws installed has throttle cable thumb throttle coil voltage regulator stock tie rods front plastic mounts rear shock linkage stock grill k&n filter footpeg heal guards stock stock water pump stock intakes stock crossover tube 45t rear sproket 41t reat sproket my phone number is 1 856 264 6004 my names tony im not trying to get rich off this stuff but im not trying to get broke either
  9. sucks he had to part out the bike but bought carbs and intakes from him EXCELLENT seller very fast shipping
  10. sorry i wasnt on here for a while yes the pipes are for sale 200 shipped but if i can get a tank for the pipes i would rather do that
  11. eh its really all around but more for mid top then anything
  12. i have the following to trade for an 5 gallon or a lil bigger oversized tank pro circuit platinums with silencers .. look great stock reed cages with reeds great condition air box stock carbs k&n with pro flow let me know i need this asap
  13. well this is my bike as it stands as of now 2002 banshee +4mill 115 rod wiseco crank noss head 20cc stroker domes own portwork v force 3 reeds +4 timing pro circuit platinums stock carbs k&n filter with pro flow 66mm pistons 16t front 40t rear as of tomorrow 35 pwks cpi inframe drag pipes are going on 1. what kind of horsepower difference am i looking at? my buddy has an all stock shee with t6s and in the short and long run hes not that far behind me. 2. could it be that the stock carbs are holding me back? what else can i do to get my bike to MOVE even faster?
  14. i never got a text from anyone its 1 856 343 2545
  15. for pics text 856 343 2545
