Building my First
Everything posted by Building my First
  1. Building my First
    A Arms
    You looking for stock or aftermarket? I have a new set of magnum plus 2 + 1 chrome never installed. I'll ship worldwide as long as its pay pal.
  2. How cheap are you thinking? I have a set of brand new magnum plus 2 + 1 never installed.
  3. I got a set in pretty good condition, platinums with 304 silencers, I can do 175 + shipping. Let me know if you're interested I can send you some pics tomorrow.
  4. Thanks for the positive feedback wisconsinz. Just so everybody's clear zach45 has a problem with wisconsinz not me.
  5. SOLD. Payment received, thanks again Wisconsinz.
  6. Inbox is cleared. I have this on ebay and have a couple bids, my reserve is set @ $1,100. I need $1,000 in my pocket. So a grand plus shipping and paypal's 3% is what I need. I will close the auction if any of you guys wants it. I will seperate after the auction if there are no takers.
  7. Saying good buy to Banshee's, till I get some property in a few years. Building a Harley now.
  8. Open to offers guys. Any takers if I break it down?
  9. I've been building this forever now. It's been taking so long because I've never had any where good to ride. I'll buy another one day when I buy some property of my own. I would consider seperating engine if I knew everything would go. If you're serious shoot me a pm or call me @ 269-906-5684. Asking $1,250 obo + shipping. Fits all years. OEM stator is a 2000. Completely rebuilt. Has never been fired up. New Cometic seals and gaskets. Bored to 64.25mm (+.010") that is first over bore. Cylinders have an aggressive port job, the cases are match ported. Builder said they would performed best with 35mm PWK's, 19cc domes & CPI's. This port job has engine dynoed @ 70 HP. He has seen 61 HP with stock carbs and Pro Circuit pipes. They are perfectly honed to the pistons. New Wiseco pistons, pins, rings & bearings. Stock crank rebuilt with All Balls bearings. It has been trued and welded by the same builder. Pro Design Cool Head with perfect condition 19cc domes and new Pro Design O-rings. Has a good condition Hinson Billet clutch basket with brand new Hinson cushions. EBC Dirt Digger heavy duty clutch kit, had 3 rides on it before rebuild was started. Clutch has a brand new BOSS Pancake Bearing adjuster. Case is in great codition no chain breaks. The trans is in excellent shape, forks, drum, gears & bearings. Has a modified shift star for smooth shifting. I will include the side covers if you want them, they are off a trail bike and don't look very good. The clutch cover has homemade Lexan window and Billet Water Pump Impeller. I will include a couple different sets of base gaskets if you want to change the piston squish. Of coarse this engine will require proper carb tuning and break-in.
  10. From what I remember a stock shee is 70 tops. Don't know what the 450 tops out at. You may have more top speed but you'll probably need room to catch up.
  11. Just wondering if they are worth buying, or would the 450 shocks still be the best bang for the buck?
  12. You made a few dollars on those.
  13. Will you seperate the intakes?
  14. Better make sur you order the tors delete cable.
  15. Looks like a rod bearing. The wrist pin rollers aren't near that big.
  16. Here is a goo thread. A little psi and a propane torch. http://forums.everything2stroke.com/showthread.php?t=35571&highlight=torch+pipes
  17. No key? Check that first, find the splice and make sure all the wires are conected. On the old one I had you just put all 6 wires together, not sure if that changed over the years. The coil ohm reading is not very reliable. I hunted down a spark issue on the 88, coil was no where near close to what clymers said, I bought a new one, it had the same reading as the old one. Thats when I found a broken solder at the key switch, fucker would only run when turning left!
  18. This was my first, the ol' 88. I'm 6' & 250lbs, look like a god damn ogre with the snow suit on.
  19. Thanks Matt, there is at least two of us with common sence.
  20. This is a negative feedback post, what is there to suck up. I find it hard to believe that you can justify his shitty description. What the fuck is this, the military? Are you two fags. Don't ask, don't tell is that what your preaching?
  21. If those were your rims and you refered to those as being nice still with only scratches and a few small dents and wouldn't say anything about wobbled lug holes and one not a true circle. Well then, Fuck you too.
  22. I put new batteries in, forgot to set the date. Pictures were taken at about 5pm today. Jesus goonie, are you trying to snuggle up to this fucker or something. He didn't say shit about wobbled lug holes. Would you call those scratches and small dents? Sounds almost like you would do the same thing to someone.
  23. $100 plus shipping, he quoted me $31 and change. I sent him $125 gift with Paypal. I think I could pull my money back listing them on ebay. The fact is he was way off on his description. I am a man of Principle, I hate assholes like this. You want to buy them Papa?
