Building my First
Everything posted by Building my First
  1. I have some old FMF Tourqe pipes with the old oval silencers. The head pipes are covered in light surface rust, no holes just an even coat of rust. One of the spring tabs are ripped off. $110 shipped http://s636.photobucket.com/albums/uu89/aj...62/FMF%20Pipes/
  2. I just got some too, look just like yours. I was about to start a thread when I came across yours. They don't look like any power jet I have ever seen, there is no jet installed in the bowl. I would like a definite answer too.
  3. I didn't think the reply went threw, damn website locked up.
  4. If it was a poxer jet itwould have a tube hanging down into the bore. Looks like a vacuum fitting or maybe your supposed to connect the carbs together, like a stock balance tube.
  5. If it was a poxer jet itwould have a tube hanging down into the bore. Looks like a vacuum fitting or maybe your supposed to connect the carbs together, like a stock balance tube.
  6. It was just the old BansheeHQ Welcome movie.
  7. This will answer alot of faq you might have. http://www.xtranormal.com/watch?e=20090312235240738
  8. Didn't blingstar or some shit like that make those heel guards?
  9. Yea, there PWK's. The base gasket thats in there now is .024".
  10. 28mm is what I really needed for my mods. I wasn't going to pass up some 33's when he mentioned trding them for stock carbs.
  11. Those carbs I traded for ended up being 28mm, he can't use a tape measure very well.
  12. Do you know where I could get a .010 base gasket?
  13. The rubber rings are just dampners. I don't think many aftermarket clutches come with them. I wouldn't use them.
  14. Finally got around to checking my squish. Mods are in my sig. Base gasket measures .024", I see most guys say between .035 & .050. Can I get a thinner base gasket or will I be fine? Squish is even on both sides of both pistons.
  15. Take the weight off the front of your shee, take one shock off, let the arms hang, measure the distance between the mounts. I think newer shee's shocks are 14 1/4". If it fits without pushing the ball joints to the limit you should be alright.
  16. Your probably running on one cylinder beacause the other is sucking air through the tap hole and running lean as a bitch on that side. Get that tap out and get an idle screw in before you run it any more and have to put a new top end in it.
  17. I think what your talking about is the rubber lining on the cage.I think that is needed on the stock cages, I don't think you want the reeds to tap against the bare metal of the cage. I've seen stock cages that have been ported and they still had the rubber.
  18. What are you asking?
  19. The'll be good carbs for you, depending on your riding style. You might find someone in this link with T5's and 34mm PJ's. http://bansheehq.com/forums/index.php?showtopic=99361
  20. Looks like a 34mm PJ.
  21. Turns out the guy measured them wrong. They are only 1 3/16" not 1 5/16", so they are 28mm PWK. It looks like they've been bored out, they measure 29.5,mm. Anyways I know these will work better with the rest of my mods so I'm happy with the trade.
  22. Doesn't matter if it's stock or aftermarket. Low budget build for one of my little brothers. Let me know what you got, may trade some banshee parts if you want.
