Bansh-eman
Everything posted by Bansh-eman
  1. will this be freeware? if not whats the going on this? also will it be downlaoded or sent on cd's?
  2. i didnt read anything beside the first post so this might have been answered... for 68mm bore the banshee weisco pistons are actually balster pistons... thats why your not finding them...
  3. the lady that did my pc charged like 15 bucks per hub...i want to say...thats to sandblast it tape it and pc it...
  4. that game i crazy addicting!!! i played it for a long time and sold my account.. made 660 bucks off of it.... but for the time put into it 660 nots shit!! what server you play? i get on my buddies account and play still
  5. you can run your stocker.. it will be fine... i have a lonestar 0 to plus 2 and i run mine on stock.... its 1 on each side... they have spacers that go on either side of the hub
  6. you can run normal premium pump gas
  7. also nice casue theres less wight for stress marks
  8. im not sure if this actually works... i have heard it before but like mark said i havent nor has anyone i known done it... to me the vineger doesnt seem to have enough acidic properties to really lossen much up... im sure theres some industrial shit you can buy but fo the most part... the distilled water flushing isnt to lossen any gunk.. its simply to remove any other chemicals tht mgith be inside your water jackets and ligering on your radiator blades...
  9. he is in england... i dont think they have home depot :biggrin: .... so your sproket hub is off already? from what i read the firs time you couldnt get that off? did i read it wrong and you just cant get the axle out of the carrier?
  10. i want to say its like .004 per inch of bore but i cant remember if thats right...... read the papers that came with your pistons it should explain it...i know that weisco 64mm bore calls for .010-.012 so i went with .011.. i dont feel like going to get my clymers to tel you the pattern... but that sounds right ... just tighten them a little each with the criss cross pattern and then torque to right spec and it will be fine...
  11. make sure when you call those basterds that they put a sticker in there.. i know a few guys that got the screens and no sticker... and they tried to not give them a sticker casue they say they only have 1 sticker per screen made... i say fuk alba... spend the money and do it right ...
  12. this might sound stupid... but your not tryying to unscrew the hub are you? its splined on there and slides right off the axle..
  13. becasue if your duning 90% of the time your not hitting no 6k rpms... so those tall dunes with the loose sand that you normally creep over cause your not sure if they drop off now your not going to be able to do so easily... so whether you want to go fast or not, itsnt reason enough to get a cub... you need to make sure it suits your riding style...
  14. you will be safe running the plate and the cdi... curve three is the most advanced of the 4 curves.... so at its max your running around 20 degrees if i recall correctly... but as you get intpo your higher rpms your cdi tapers back to gain some of the top end back
  15. no... only thing that will give you a stronger spark is a coil... cdi's and stators will not make your spark stronger... how every say your running a 100watt stator and your running 100 watts of lights then obviously your not going to have enough power to run both... but adding a higher output stator will not make your spark change
  16. 21's and 22's would be too large... your not pulling enough power to spin those without losing alot ... id say a 20x10x8 on 8inch 9 paddle hauler would be in the ball park... enough to dune and not too many to loose your wheel spin for dragin...
  17. ok i think im going break down and do something i said i wouldnt do.... im thinking of going with silver and blue flames... start silver and fade them to blue.... and have ghosted skulls look like they are coming out of the plastcis... my frame has the metallic sparkle so maybe do some of that too...
  18. ahh not a bad idea... google ftw
  19. so both should work... looks like distilled just has less impurities
  20. if you can find some thicker SS mesh you should be ok casue the stickers are really what your paying for... the ones from alba are so fukin thin they burnt up in no time...
  21. Mark, you sure you didnt move to san francisco? you sound like a GAY!!!
  22. those screens we posted are only a temparary fix... they will burn holes right through them after a few rides
  23. oh sry that was actually more for mike... his buddy did alot of flame and tribal work on bikes...
  24. thats not a "master link" its nothing more then pressing the pins from the chain to bind the 2 ends together... we did this when i raced go karts... never used masters for it... i have heard that people have had problems with the chains breaking doing this but im not very sure if i belive it ... to me it seems like it would be stonger...
  25. im not much into flames and tribal... i got all my billet plain and shiney... so i dont think i want all that on my palstics... i do like skulls and shit but i think thats more of a place for a tatt and not a bike... my issue is i dont really know what i want and im not an artistic person... thats why im hoping i can get some ideas off you guys to hopfully spark something in my brain housing group
